chaiyuta
@Whitigir : For AMP4s, Do you have any physical issue with Pentaconn 4.4mm. plug?
Not to take away from the 4s impressions - wish I had something to hook into mine lol - Anyone ever notice intermittent static noise when streaming Tidal or even just in the app no music playing? Same goes for Tidal via UAPP. I only get it in left channel as well.
Could this just be the byproduct of living in a condo? Wifi pollution?? I would say it sounds identical to what a dirty pot sounds like. That same scratchy noise but very, very quiet. Can't hear it with music playing save for extremely quite passages. It's extra bad (read: continuous, same volume though) after pushing play while waiting for track to play. I can at least say this is not firmware related having tried that.
Are you sure this setup ever charged DX200? I'm in doubt because "USB host" (DX200) must provide power to "USB device" (iDefender/HDD), not vice versa.It should work like we connect.
It seems like AMP4s already run out of stock now. This is a lesson for anyone who is interested on limited amp module wouldn't wait for review...
Ah yes, I get the dip tooI have exactly the same issue. I can hear some electric sounds and a buzz through the left channel only. It’s annoying. I even hear from time to time a strange bip.
No more issue on amp4s.@Whitigir : For AMP4s, Do you have any physical issue with Pentaconn 4.4mm. plug?
I may have screwed my AMP4 up...my cat knocked the DX200 off the desk with the adapter in...now I have a little wobbly connection and some minor static going on...
Schiit... @Whitigir will the fix you put up help this? I might need a hand...lol
As long as it’s as good as the screwdriver that came with Amp 3 or better, I’ll settle for thatNo special edition for you ? Sad! Should have it made out of pure meteorite of six nines purity
Not sure what you've tried yet but if you don't use a 5Ghz WiFi connection you are prone to noise on the DX200. Switch to 5G and it should stop (assuming I've understood your issue currently and the noise occurs when streaming).Ah yes, I get the dip too
I posted this in the Bug/Issue thread but I guess it will get a broader view here.
There's a recent Amazon review from an Android developer https://www.amazon.ca/iBasso-DX200-Resolution-Supporting-Connection/dp/B01MTEVQ1B#customerReviews
Here's a quote from it:
"Wifi Audio Interference - One of the first things I did when I got my DX200 was to install TIDAL. A lossless music streaming service on a DAP of this caliber was just a no-brainer, but I was immediately frustrated. While listening, I quickly noticed intermittent static in the left ear. I thought it was a short in my headphones until I realized that it didn't happen when in MangoOS mode. At this point, I thought it was just a TIDAL issue, but then I started using the DX200 to browse the internet one day while listening and immediately noticed that downloading data cause the issue. Loading any amount of data over wifi will cause the interference. Turn off the wifi and it goes away. The worst part about this bug is that I doubt this is fixable with a firmware update. My guess would be that this is a hardware design issue, but I would be absolutely thrilled if I was wrong!"
I really thought it was just me, figuring this would've been brought up before. Then I found another member in the DX200 B/I thread reporting the same annoyance. I'm not fond of the clicks, cricks, floobs or fleebs I'm getting out of this thing, but it sure does play music well! I did get some loud buzzing at times when I streamed A a A a A Very Good Song (Silent Track) by Samir Mezrahi. Lot's of room for the musicians to explore in this piece.
I'll be honest though, I just tried it now and other than the noises leading up to the song starting, noise free after that. Now it is 2:45am here. Matter? Maybe.
The balanced amps always did sound tighter than the SE ones, so an improved AMP5 does sound interesting. How does the treble on AMP4s compare to AMP5? Is it less of a peak?To my ears amp5 sounds kind of little muddy warm compared to amp4s has layers and articulate warming sound with some details... I do not know if it is because of different IEMs/CIEMs.
That is why most of headfiers here raved the amp4.
+1 issue is with lower band width, no issue at 5G.Not sure what you've tried yet but if you don't use a 5Ghz WiFi connection you are prone to noise on the DX200. Switch to 5G and it should stop (assuming I've understood your issue currently and the noise occurs when streaming).
