koluludome
- Apr 16, 2015
Is HD800 and dx200 is going well together ?
HD800 is an easy-peasy for DX200.
Well this is hard to tell. Everyone has a different definition of "effectively driven". For me, although I listen to music a lot, I'm quite protective to my ears. So for me, when listening to classical music at home or a quiet place, around 85 - 95 of volume on high gain can already drive the HD800 with a sufficient volume. When push to 115-120, the volume on HD800 is already quite intolerable for me. About the direct driven sound quality, I would say it's already quite good for a portable DAP. Of course it's not as good as driven by my tube amp, but the instrument separation and the details of the sound are already on point. On my tube amp, the orchestra sounds like performing on stage with distance. On DX200, it sounds like performing surrounding me which means less airiness. But the details, high extension, separation, etc. is on point. DX200 can drive HD800 with ok sound stage, just not as good as with my tube amp.Are you able to drive the HD800 without an amp easily? If so, then the dx200 definitely gets on top of my list
Try android mode, it is snappier than Mango OS mode.
Try open development option, and set all animation scale to .5x. It will give you a little faster when transition.
I'm sure Paul said there is literally zero difference in SQ when using the stripped down version over the full. The mind will often hear what it subconsciously wants/expects to hear. Then again, maybe there is a difference.
Paul, you little devil you...
I already tried. It's not only a big lag, the touch screen doesn't work properly, it's not responsive. I put my finger many times in many parts of the screen and nothing happens.
Stay updated on iBasso at their sponsor profile on Head-Fi.
jeffhawke
I wanna ask about their sound signature is compliment to each other or not, not how it drive the headphone
They work together quite well If you are a classical music listener, then this combination is just for you. The analytical ability on dx200 is like a beast. I dare to say that it even presents details better than AK380+amp。Also it has great soundstage and separation. So with the HD800, the whole presentation is quite united. Very opened and live like sounding with accurate and least colored realistic tonality.
I do not remember saying this. If I did I would take it back.
I am bad?
Have you updated to the latest FW? Some screens had issues and the latest FW solved this.
Mine reached Australia quickly, 2-3 days. Then the TNT courier driver decided he'd drive my DX200 around Sydney in his van for 2-days before casually knocking on my door late in the afternoon asking if I could walk down to his van and get it..
The rage was real.
Try open development option, and set all animation scale to .5x. It will gie you a little faster when transition.
Anyone can comment the battery life in Dx200? How many hours do you get for a continuous play?
