Just took a quick break from burn in (24hrs playing non-stop so far) to hear the progress, and indeed sound is starting to open up nicely. Don't want to jump into sound analysis yet since it needs more hours, but dx200 is already starting to approach LPG level of performance in terms of soundstage expansion, transparency, and resolution. I'm definitely seeing high potential.
Updated to the latest firmware and did the factory reset. Keep in mind, Factory reset will erase all the music from internal memory and all the apps that you have installed, bringing it back to the factory default setting. So, I would advice keeping music on uSD card since factory reset shouldn't touch it. Another observation, just like with X7, you will have Android Mode and Mango mode (like a pure music mode). When you start DX200, by default it loads Android Mode and you can use Mango audio player, but it's just a player and you are still in Android mode where you can stream and run other apps. Pressing and holding Power button will give you an option to Shut down, Reboot, or Switch to Mango OS mode (the pure music mode). When you switch to that mode, interface is nearly identical to DX80.
I did a quick test with a number of C/IEMs, sorry, still a bit obsessed with hissing. Now, I hear Andromeda nearly quiet, and so does other iems like K10UA, U12, W900, UERR, Vega, IT03. The ES60 has a very faint hissing. So, it's only down to Zeus XRA (using it with PWA 1960 4wire cable) which has a noticeable hissing. Everything else is pretty quiet when I pause the music, and most of my cables are balanced terminated so majority of testing was done from 2.5mm port. Btw, FANTASTIC pair up with IT03 + CB12 (iBasso's 8-conductor hybrid balanced cable), and that's only after 24hrs of burn in. Great pair up with Vega too. Not everything else had the best pair up, but it's too early to jump into any conclusion since burn in is still in progress and the sound is still changing.
A few issues were already mentioned. There is a click when switching between sampling rates (44.1kHz and 48kHz), but not when you are playing songs with a same sampling rate. I would like to see a touch screen volume slider (like in A&K or Opus daps, or i5/X7) for a quick volume adjustment, otherwise takes a bit too long turning the volume knob when you switch between headphones with different sensitivity.. Under Mango OS "pure music" mode, I noticed clock stays in 24hr format. In Mango music app, the fast forward bar time marker is rather big and square, while I like a cleaner look of Mango OS player and it's "dot" marker.
Not too crazy about leather case. I mean, it works, but I got a bit spoiled with Dignis cases. The biggest gripe here is that on the front it extends and covers half of the volume wheel, making it harder to reach it. But I still prefer using leather case for a more secure grip, rather than going naked.
As others mentioned, packaging is pure class, definitely gives you a feeling you are dealing with a premium product. USB-C cable is high quality, looks nice.
Will continue with a burn in to get to 100hr mark before sharing any sound impressions. But so far I'm impressed!
