Lurker0
No way: if you prefer b2, why can't I think that you prefer 1.10 over 1.12? And that's what I thought!I also guess that you might have used a few seconds more and pointed me in that direction,
Yes, I understand that, but what's the purpose of USB audio then? I thought it makes the player of your choice (of those supported) fully utilize DAP capabilities, like Mango. Thanks.There is no way for software to bypass the hardwareAny software player on a DAP utilizes DAPs hardware. I have no idea why do you think that Google Music sounds better or worse than Neutron with the same file. I'd suggest you to listen music
In April, 2017, when I introduced it, it was true. But, even then and now, it always means to play bit perfect hi-res and DSD, i.e. formats that are not supported by Android sound system via documented way. I never bothered about 16/44 and even 16/48 PCM.what's the purpose of USB audio then? I thought it makes the player of your choice (of those supported) fully utilize DAP capabilities, like Mango
Update.
After some fumbling around I got the DX200 to be recognized. I ended up keeping the DAP connected to the USB-C end of the cable and disconnecting/reconnecting the USB-A side from the computer USB I/O. After a couple of tries it took. Tool saw the dap and FW update worked!
But now I've ran into the same problem just to get the DX200 to be recognized as a storage device. Need to also install Lurker0 FW mod so going through the same rigmarole now.
did you install the rockchip adb driver, located in the folder\; 1.DriverAssitant_v4.5
FYI mass storage ("Card Reader" mode) in Mango never worked with official firmwareHad the same trouble making my dx200 under Mango recognized as a mass storage. Had to go Android to solve this. First time it happened.
