DIY Cable Questions and Comments Thread
post-15209516
Post #9,227 of 9,560
Matthew420
Los Angeles
Los Angeles
post-15213367
Post #9,228 of 9,560
sworder84
Russia
Russia
Hello, guys. Has anyone compared Mogami 2893 and 2534 by sound? Is there any difference beetwen them?
I buyed a few meters of 2893 for my HE 560 and just ordered a 2.5mm connectors. I did not found of W2534 in my town - out of stock!
Maybe later I will change the cable on OCC copper if the last one would better than Mogami. What do you think?
post-15213405
Post #9,229 of 9,560
Matthew420
Los Angeles
Los Angeles
I haven't A/B tested those two. But if you have two cables of the same material, and one of them is 25 AWG and the other is 26, you'll probably be able to tell a difference.
post-15214585
Post #9,230 of 9,560
sworder84
Russia
Russia
Now I have only W2893. I saw 2534 on eBay and markertek but it's need to order. Anyway I'm waiting for connectors now. Tnank you for advice!
post-15214629
Post #9,231 of 9,560
imas69
If there is a difference it will be so slight so I would order what I could, even Canare or Van Damme is fine, it's all silver plated ofc
post-15214641
Post #9,232 of 9,560
Matthew420
Los Angeles
Los Angeles
Yeah, don't be hung up on any particular brand or model. Most of the stuff that makes one mic cable better than another really doesn't have any effect on our uses. I'm not sure, but I don't think anybody's making an OCC-wire mic cable. So if you're talking OFC, the biggest driver of sonic improvement is going to be wire gauge.
And if you already HAVE 26 gauge wire, your gains from getting new 25 gauge wire won't be worth the money or the wait.
post-15214669
Post #9,233 of 9,560
sworder84
Russia
Russia
I think headphones more like a copper cable than silver. I also have a custom argentiferous cable (my friend made it for me). But I don't know what kind this cable (noname). Sound is good but a little cold and sharp sometimes. That's why I want to made another cable with Cu conductors.
Which gauge of wire is optimal for headphones?
post-15216515
Post #9,234 of 9,560
Matthew420
Los Angeles
Los Angeles
I tried to start learning how to braid eight strands this morning. It's hard to keep track of which strand is which. Does anybody have any useful wire management suggestions?
post-15216535
Post #9,235 of 9,560
doctorjuggles
London, UK
London, UK
Well I’ve personally never done any cabling in my life, but if it was me I’d wrap a different coloured string or piece of cotton or even colour in some pieces of paper and tape them to each end of each strand. Would that work?
post-15216565
Post #9,236 of 9,560
imas69
Turn the TV off, put your headphones on and just keep trying and it gets easier every time but your main weapon is concentration, the worst thing is losing
your train of thought, I'm not very good at it because I keep thinking about chocolate
Reactions: Matthew420
post-15219915
Post #9,237 of 9,560
teknorob23
UK
UK
Website
www.springloadedfilms.com
Hi All, i'm putting together a replacement cable for a pair of Beyer DT1770 HPs which have a single cable connecting by 3 pin mini xlr to the left cup. So i'm making a trs 6.35 - Mini 3 pin XLR.
I've made the cable according to this wiring diagram and i am only getting signal out to the left channel. Ive checked the XLR and jack and all corresponding contacts are connecting correctly.
My question, is this correct wiring diagram and or have i missed something really obvious?
post-15219947
Post #9,238 of 9,560
Wes S
Plano, TX
Plano, TX
Age
41
Good timing! I just twisted up some UP OCC wire for a cable for my DT1770's, and was wondering about the wiring as well. I think your postive and negative are switched. I believe the positive is pin 2 and negative is pin 3. The ground is pin 1.
post-15219950
Post #9,239 of 9,560
-Hodor-
Germany
Germany
The wiring in your Picture is correct, check the cable with a multimeter to see what your resistances etc are (specificly the connection pin 2 -> ring)
post-15219962
Post #9,240 of 9,560
RestlessZombi
London, UK
London, UK
Have you tested with a multi-meter from the XLR end to the TRS end for continuity? check each pin from one end to the other. Also check that none of the connections are also connected to the other, so right isn't accidentally connecting to ground too.
I can't see anything wrong with your wiring diagram, but if you have the old cable that would be the best reference to check with. There is a guide to swapping out the XLR by Demevalos that seems to confirm the pin layout here : https://imgur.com/a/tMd7Cn7
Double check your using the right pin 1, 2, and 3 in the XLR. I'm not sure if none of this works, beyond cracking open the headphones and checking the continuity from the speak to TRS jack...
Reactions: teknorob23
Users Who Are Viewing This Thread (Users: 2, Guests: 2)
  • Top
