DIY Cable Questions and Comments Thread
Oct 1, 2019 at 9:03 AM Post #9,241 of 10,589
The wiring in your Picture is correct, check the cable with a multimeter to see what your resistances etc are (specificly the connection pin 2 -> ring)
i'm stuck at this with one channel :0
Oct 1, 2019 at 9:29 AM Post #9,242 of 10,589
oh I think I know what the issue might be:
That picture is only halfway correct. Its drawn correctly, however the labeling on the XLR is wrong:
Pin 1 is top left (ground)
Pin 2 is bottom middle (right channel)
Pin 3 is top right (left channel)
Oct 1, 2019 at 9:34 AM Post #9,243 of 10,589
XLRs are a little tricky, because you don't know from the wiring diagram whether you're looking at the pins from the back or the front. And the TR(R(R))S ones can be a little tricky, too. So just always check with a multimeter.
Oct 1, 2019 at 9:42 AM Post #9,244 of 10,589
That is correct, and exactly what I said a few post ago. Just go by the numbers in the pictures, regardless of their orientation.
Oct 1, 2019 at 9:52 AM Post #9,245 of 10,589
so just confirm this is how it should be wired looking at the back of the plug?
Oct 1, 2019 at 9:55 AM Post #9,246 of 10,589
That is correct. I hope it works out for you.
Oct 1, 2019 at 9:56 AM Post #9,247 of 10,589
Briliant thank you and thank you everyone else too. I'll have another crack and hopefully report back with success :)Rob
Oct 2, 2019 at 4:09 AM Post #9,249 of 10,589
I'm seriously question the authenticity of these cables because you don't find such cable on Neotech site.
Agreed, but neotech do supply upocc wire to lots of third party companies. Still don’t think I’d go for it
Oct 2, 2019 at 4:14 AM Post #9,250 of 10,589
They supply it to 3rd parties (as claimed by 3rd parties) but don't list it on their website? This seems kinda shady. Also, the headphone cable that is listed on Neotech site looks too dissimilar to the ones listed on AliExpress. All in all, I think I'll pass.
Any real UPOCC 7N copper cables out there? Here're a few that I could find, but didn't try:
https://forzaaudioworks.com/en/product.php?id_product=22
http://www.norneaudio.com/litzheim/...em-iem-full-size-aftermarket-up-7-n-6-upgrade
Oct 2, 2019 at 4:36 AM Post #9,251 of 10,589
I’d avoid neotechs preprepared iem cable and go for there hook up cable in either copper, silver or silver gold upocc. I’ve tried lots of alternative upocc and nothing sounds as good to my ears as the neotech branded wire and the copper at least is pretty inexpensive where the 22awg is a bit of a sweet spot for hp cables in terms of sound, ergonomics and price.
https://www.hificollective.co.uk/wires/neotech-stdct-multistrand-copper-wires.html
Oct 2, 2019 at 4:44 AM Post #9,252 of 10,589
Would it be too stiff if I'd want to make 8 core cable with it (24AWG)? Also, red sheathing sucks.
Has anyone wondered what wire is used in Brise Audio Yatono? Also the outer sheathing looks like a matte resin. I wasn't able to find such bulk cable online.
Oct 2, 2019 at 5:02 AM Post #9,253 of 10,589
I've made quite a few 8 x 24awg cores varying from 1.5 to 5m cables, and yes it is stiffer than a 4 core, but still not what i called stiff and i havent had any complaints from those who i made them for. This wire is teflon coated which is considered the best performing sheathing for hook up wire, but probably less important for HP cables. Pricing on neotech wire seems pretty consistent world-wide but i have found a few anomalies, where specfic wire is cheaper from certain sellers. E.g silver/gold 24AWG which is £56 per metre in the UK, is closer to £40 in Latvia and ukraine.
Oct 2, 2019 at 5:05 AM Post #9,254 of 10,589
I seriously question the authenticity of these cables because you don't find such cables on Neotech site.
that was my first thought when saw these PE sheathed wires and couldn't find them at their site. btw, they have added some wires to their site (neotech) which i couldn't find before.. at the beginning, the only hook up wire listed in their site were copper, soc, and silver, with teflon or pvc sleeved, iirc.
then, i saw cables using same PE sleeved wires in boutique shops, like null audio, norne, forza audioworks, and others.
then, searched for these wires at distributors; hificollective, where i use to buy the wire, and chinese distributors (taobao). i found these wires in the latter, together with the known wires listed at neotech (same product page in many cases).
LOL. these wires are not listed at neotech site either. why do you believe these are legit, and the same wires listed at a chinese shop are fake? just because they are chinese?
better do what @teknorob23 suggests. buy a wire which is listed at neotech site, and DIY yourself.
Oct 2, 2019 at 5:48 AM Post #9,255 of 10,589
Where do I claim or ask that/if they're Neotech? I only spoke about 7N UP-OCC.
I feel that all this 7N stuff is pure marketing. Even Neotech claims only 5N on this site: https://www.hificollective.co.uk/wires/neotech-stdct-multistrand-copper-wires.html
This article pretty much supports this too: https://doublehelixcables.com/faq/
Does anyone have any firsthand experience with the aforementioned cables?
