Edwii
- Jan 7, 2015
Any kind of cables will work, even those cheap electrical/light bulb cables will work. Just browse around and get the cable that appeals to you most. While there are neverending debates on different cables yields different sound quality, personally I haven't experienced any solid facts about it. Just take a few things in consideration:
- how thick is the cable you want. Thicker will be better in durability, but more bulky, stiff, and heavy
- what kind of cable do you want, the sandwiched type (all polarities encased in 1 jacket), or the single polarity type (1 polarity in each cables)
- aesthetic, which cable is the most easy on your eyes. You can also use paracord sleeving to remedy ugly looking cables
- your budget. Audio cables can go from $1/m to over $100/m
That's what I mean, I want something above average. Shielded and will work well even at 20feet. but i dont know what to pick? I'd spend between
$0.80 - $2 per foot, give or take.
