ThurstonX
The coupled male RCA cable test was successful. Now I've got a request re: constructing the Female-to-Male extension cable. I've got some four-conductor Mogami (W2893, IIRC) that's still sheathed and shielded (left over from a Redco custom cable I've already started cannibalizing), and I've got plenty of fixed installation W2799 that would be easier to work with. I'd like to use the bulkier, shielded cable, but I'm wondering about the best way to expose and solder the two pairs I need for the RCA connectors.
Should I just strip away as much as I need, put some heat shrink around it (?), then solder? It won't look pretty, but I'm sure I can make it functional. Or should I use the W2799 and feed it through some paracord? I guess the basic question is, what's the best way to make a two-channel cable that's one thick cable in the middle up until the split ends?
If you've done it and have photos, that'd be great.
TIA.
TIA.
