Saburo2020
- Feb 26, 2016
Treasure them!
I'm going to but it's hard since they're not working
Hope someone already found a fix. Anyone?
Treasure them!
Hi All,
I've been watching this forum for few years now and always had luck with finding answers. Not this time unfortunatelly. At least not the answer I'd like to get.
Long story short... I have a pair of AH-D2000 with broken driver. I found few threads where ppl descibed same issue. There were 2 fixes:
1) Sell and buy new ones
2) Replace driver
Searching through Internet I found lots of posts written by ppl with similar issues, so it looks like there is something wrong with AH-D2000 drivers.
I'm wondering if after all these years anyone solved this mystery? Why it happens and if there is a fix for that? (fixing coil or something)
Regards,
S.
Truer words have never been spoken here on Head Fi.
For me; After over 30 headphones in around 10 years ( yes, you read that correctly! ) none compare to the magic of my old AH-D5000's. They have this unique ability to capture the mood of a recording. This ability is absent in every other headphone i've ever heard.
They where definitely a one-off. Treasure them!
and none of the current crop of same physical unit style Fostex outdo the D5k in your opinion
Hi All,
2) Replace driver
Regards,
S.
Happy End... after all it turned out that cold solder joint on one of coil ends is the one to blame. Quick re-soldering worked like a charm.
and none of the current crop of same physical unit style Fostex outdo the D5k in your opinion ?
i own the FostexTH500RP and parts look very similar as a matter of fact pads are interchangeable that includes the plastic ring that holds the pads and gimble assembly looks very similar
It did work but for few days. Now it's the same and it looks like it can't be fixed after all
That brings me to question do any of you guys have a broken paid of AH-D2000 and wish to sell one driver?
(I was going to add new sell/trade post but I guess I don't have permissions to do that).
