plonter
- Oct 18, 2008
what is the parallel for the AH-D5000 ?
Going to have a run of Burmese Ironwood proto woodie cups going half price in the F/S over next week or so.Aprrox 1 set ready per week. Run of 4 sets for D2k and 1 set for 5K/7K to recover my costs on first run errors etc....and my own cans will finally be put back together again.....after so long ;-( Will be stained and lacquered....5 color choices uploaded later. Will be using different wood on next lot, but for now this was my best option in proto phase.
Looking forward to seeing these.
$99 inc. tracked international shipping on proto batch. I have photos right here, but not sanded or stained as yet. Target is 1 set per week on-going on proto run. If you take stock plastic cups as small size, these are medium sized and will also do deep dish cups as well.
Going to have a run of Burmese Ironwood proto woodie cups going half price in the F/S over next week or so.Approx 1 set ready per week. Run of 4 sets for D2k and 1 set for 5K/7K to recover my costs on first run errors etc....and my own cans will finally be put back together again.....after so long ;-( Will be stained and lacquered....5 color choices uploaded later. Will be using different wood on next lot, but for now this was my best option in proto phase.
Lawton is Out but Martin Custom does the best work at a good price. Paid $250 installed for COCOBOLO cups but he just moved and is not up and working yet I think. Even when he gets up and running you have to be patient as it will require you to send your phones in and be without them a coup,e months at least.
There's a couple other guys doing cups - Folex had some made but not sure if he's offering to make them for folks yet, and member Lohb is going to be in the biz soon. He will be worth waiting for I think.
I put the D5k cups back on my D2000. This time I added a little cotton and the flabbiness seems to be gone. I'm loving how they sound...and I don't think I'll ever put the plastic cup on again.
Just received my D5000 yesterday. These headphones are beautiful and I didn't think it's as flimsy as some head-fiers make it out to be. Comfort levels are top notch.
Had a listen for about an hour with a mixture of Electronica and Slow Rock songs. Bass is fast/accurate but is a little overwhelming/punchy for me, especially on certain bass-heavy recordings.
Struggled with some treble peaks as well in what I felt was harshness.
I'm a fairly low volume listener but after the hour I had to take off the D5000. Had a slight headache for a couple of hours. Unsure at this point if it's the bass or treble peaks that were causing the headache.
Don't get me wrong. I think these are great cans and I'd love to listen to them all day. Might just have to avoid certain recordings on them for the time being.
The piercing highs will be tamed, as will the overwhelming bass. And your headaches should subside.
I might have some information regarding Lohb's cup shortly. He sent me a message, and I'll let you guys know, what I know if he decides to carry out the actions he specified in his email
that sat how ever, I would wait for him. His products are rather nice, I've got some wood cups for my HE 4 from him
It's been several years since I opened the box on my D5000, but my memories of that time are EXACTLY as you described. I bet if I go back into my old Head-Fi posts, I probably see many of the same phrases you used.
If you can swing it, send the D5000 to Lawton Audio. Get the tuning and angle pads. The piercing highs will be tamed, as will the overwhelming bass. And your headaches should subside.
Note that before I went the LA route, I tried using the Gilmore Lite amp to tame the bass. Was mildly successful, but it did nothing for the treble. Also tried the Darkvoice 332 amp and a few different tubes. It mostly brought more mids and unnecessary depth to the bass.
Now I use a Objective2 amp and ODAC with great results.
Good luck!
