- Aug 25, 2013
I used paxmate instead, its not as effective a dampener but you also don't have to deal with any of this foil stuff.
I've actually been using paxmate in my computer case for many years. Yeah it wont be as effective just because foam does not have much mass. Might help with reflections though.
I wonder if you could use paxmate on top of foil Dynamat.
So I just put a square 3/4 x 3/4 inch of silverstone earside over the driver and behind the earpad with a spine cut out of the gummy back to let the wave come though vs hitting a wall of sticky gum... (this is a tip from the T50RP mod thread.)You just pinch the square so it is folding sticky side out and cut a "spine line" out of the sticky back side then slap it over the driver grill.
It has tamed the treble spike at a stroke for me anyway. I can raise the volume higher without the treble racing ahead so much.
YMMV as I'm treble sensitive.
It takes a minute and you don't have to dive inside the cans except unscrewing the earcups.
Have you guys have heard of anyone using vinyl dampening materials for earcups?
Such as this:
http://www.parts-express.com/sonic-barrier-lightweight-vinyl-sound-damping-sheet-10-x-13--268-030
The surface looks reflective vs absorbing in the second photo....
I thought all dynamat-type mods have a foil like material on it? Can you even peel the foil material off of dynamat?
My D2000 broke today. After 2 years of everyday use right cup fell off. So sad. Impulsively bought Audio-Technica WS77 for a temporary replacement, they're good, but i already miss a supreme comfiness of D2000.
Lawton is now using Fatmat which has a version that is not foil backed.
To listen to Mark describe it, I seem to remember he said it was about dissipating Heat and vibrations..his words.........I dunno, but the man did develop an epic mod.
So did you guys get a significant taming of treble when you modded or had yours modded ?
My only success in taming the treble, especially sibilance in human voices, was by gluing felt discs in the drivers' protection grills, as described here (I'm currently using two discs on each side): http://www.head-fi.org/t/350721/denon-d2000-d5000-md2000-md5000-appreciation-thread/3495#post_10348740
I did that inspired by a mod suggested by BlueMonkeyFlyer for MrSpeakers' Alpha Dogs. So far, no one has done this for the Denon headphones or, for that matter, the Fostexes that share the same construction design. So, I'm not sure if it will help others too.
You (Mshenay) might want to check out the LCD-2 thread and search by photos....one guy in Russia modded an LCD-2 to a better sound than LCD-XC.... http://www.head-fi.org/t/509710/audeze-lcd-2-impressions-thread/2715#post_10385664
You'll save a fortune picking up a used pre-fazor LCD-2 circa $750-$800 (that still has that deep and dark bass intact) and messing around with damping/wood enclosure cup....
Back on topic, regarding the damping material, i just picked up an exact duplicate of Sliverstone foam used for A/C units at a fraction of branded car audio stuff (just got that tip off a sub-woofer car outfit place locally)...so if you are doing your own mod, track down some lagging sponge with no reflective backing meant for a/c installation.....since it is supposed to DAMP not reflect...LOL
