Just pull the pads off? That's inferior to Fostex's turn and click mechanism.
Denon AH-7200
- Thread starter obsidyen
- Tags
- ah-7200 denon denon ah-7200
MR. Hmm
- Apr 17, 2009
I've had the Denon D7200 for a few days now and I really enjoy the sound, however I find that they let a bit too much sound in for my taste. Is there any chance that changing the pads to a different type will give better isolation than the stock pads? If so which would you recommend? I'd hate to send them back as they do every thing else right.
cute
- Mar 26, 2010
You can snap the pads along with the black rings off with gentle force. There are 5 Torx screws locking the frame and driver housing.
Thanks for the pictures! I think this internal design would eliminate the possibility of DIY drop in replacement cups, ie Lawton???
GU1DO
- Sep 20, 2015
No worries. Looking at the pics of the D7200 and the Fostex immediately below they look very similar (near identical attachment slots) so would assume they must be using a ring of some kind. Whether it is detachable or glued to the pads I'm not sure but hopefully another member will be able to confirm!
they are not the same as fostex rings ,, you have to pull the black ring ( no twist ) ,
i dont like the new attachment mechanism , latches are prone to break easily ..
GU1DO
- Sep 20, 2015
There are a lot of good quality lambskin pads around now, Lawton, Dekoni, ZMF, Mr Speakers......IMO they tune your prefs just as tube rolling, DAC/Amp and cable. Which is why we all hear differently.
Thanks Frank, my Denon D7200 will be here this week, hope it has the reference flat sound as advertised.
cant wait for your comparison with Ether C ,, i ordered one for my self but it will take 2-3 weeks to arrive ..
markl
Hangin' with the monkeys.
Member of the Trade: Lawton Audio
- Jun 22, 2001
Hi xinghui0711
Thank you for the pics.
Would it be possible to get a few close-up pics of the rear of the driver assembly (this piece):
Also, the interior of the wood cups would be useful much obliged. Cheers.
Mark
Mark
Those black pad rings look like they work much like the original HiFiMan rings that snap in place without the twisting like the Fostex/Denon earlier models.
jellofund
Yes, you are correct. The pic I was looking at (post #97) may have been a pre-production unit as that one does appear to using the same attachment system as Fostex.
As Oregonian says the production rings are somewhat similar to those used by Hifiman which I don't personally like for the same reason as you. Makes me wonder why Denon decided to change it.
- May 3, 2009
Had a brief audition of the D7200 last weekend. It's pretty impressive what Denon have achieved here with the much improved build and seems to be a flatter sound than the Fostex at very reasonable price for the current headphone flagship market.
Fegefeuer
- Mar 17, 2011
Love the balance overall and the soundstage is expansive enough. EDM hits very hard with this headphone on my setup, though of course at the very lowest octaves the TH-900 pushes more db.
The only Fostex derivate that could make me replace the 7200 would be a new Fostex Flagship that fixes the peaks thoroughly and doesn't have a laughable price.
If I look at the pics I see previous generation Lawton cups won't fit, the screws are simply in a different place.
The pads look about the same size to me but I'm not a fan of the new non-twisting mechanism either, prone to breaking.
- May 26, 2009
My review is live - I will also try the Lawton pads this week when time permits and let you know if they work or not and [post a picture.
jmills8
Previously known as bmiamihk, jmills2
By Live you mean ? Where ?My review is live - I will also try the Lawton pads this week when time permits and let you know if they work or not and [post a picture.
ruhenheiM
- Dec 27, 2010
i'm assuming this one
http://headphone.guru/denon-ah-d7200-return-magic-sound/
Kukua
- Jan 16, 2014
masterfully reviewed, however why are they so difficult to get as availability is severely limited.i'm assuming this one
Total: 6 (members: 0, guests: 6)
