SilverEars
- Sep 18, 2013
Yeah, I could care less if somebody heard something at a show and was impressed at first listen. LOL. Don't give a damn.
Like I said, he heard a prototype at a show, so nobody has it yet. If you want to call him a shill, go right ahead....no need to *****foot around it.
The Tera is more "rounded" or smoother than my stock 240. The other side of the coin is that Tera is less wide in terms of sound stage and less in micro details.
240 is much more analytical and with more power at the low end (might be the case of lower output impedance). 240 is more skill towards digital (only when compared to Tera) than analogue (like Tera).
I've found to amp (using Vorzuge Duo, Tralucent uber interconnector) Tera would get better result with more punch and better overall balance without losing the analogue feel of the DAP.
If you are referring to the X5, the line out bypasses the internal amp and is not influenced by the volume control.
By not influenced by volume control, you mean even if I attempt to change the digital volume, the Fiio's proprietary OS will not allow me to and grey out the option?
I mean that you can continue to adjust the volume in the firmware but it will have no influence on the line out volume. This is actually handy. If you switch back and forth between the headphone out and the line out, you can leave the HP volume as it is.
How about the X3? I noticed it has a line output jack on the bottom.
When an external amp is plugged into the line output of the fiio x3, will it also not be influenced by the volume control.
I am only discussing the X5 - never used the X3.
I always thought on the x3 and x5, well until now that the line-out was from the 3.5mm headphone jack hence double amping.
Re X5: You were wrong. It is a separate line out jack.
If i remember correcrly, u cannot control vol from X3 when using LO. Its set to 1.7V
What that the value 1.7V mean?
1.7Vrms
Line level output level. Are you planning to amp your X3? Sorry i didnt read all youe previous messages. U can also email Fiio before buy.
Not trying to argue with you but if the volume is adjustable in the firmware how can there be no influence on the line out volume?
Doesn't it mean the internal amp of the x5 is playing a part thus not 100% bypassing it?
Sorry I don't quite understand
Snohomish
No problem. It means the opposite. Adjusting the volume in the firmware affects the amp's volume. Since the line out bypasses the X5's amp, adjusting volume in the firmware does not affect the line out volume.
So sound wise would be the some if:
- the volume pot on the external amp set to 1, and digital volume set to 4
or
- external amp volume set 4 and digital volume set to 1
