ZARIM
IP address matches SNOOP_DOGG and HFAUDIOPHILE.
- Dec 24, 2006
You can use both 3.5mm to RCA with AMPs(for headphone surround sound) or RCA cable.....
Low impedance alone doesn't necessarily make headphones being easier to drive.
Overall, I think you did well in going with the Asgard rather than the Valhalla, as both the headphones and the soundcard will pair better with the Asgard's sonic traits.
well hello again MR roller .
well I took your advice and read some reviews and comments bout the asgard and you were right, so I went for it, so now that the spending is already done if you don`t mind giving me some insight about how low impedance headphones benefits from an amp?
and another thing how do you calculate the 1/8 rule or the 0impendance of a sound source or an amp?
It's the amp's duty to drive the headphones properly, given that they're adequately matched. Keep in mind that different amps have different characteristics, both in specs and in signature.
Basically, the D5000 don't absolutely need amping to sound ok, but they will sound great with additional amping, and both games and movies will certainly benefit from that.
Budget is the buyer's consideration alone, as the D5000 are worth their price tag, IMO. If the headphones fit the needs of the buyer, then it's his own decision to make whether they're worthy enough.
And yes, if all goes well and you take good care of your gear, you should be able to use it for many years to come.
About cars, I would certainly like some quality rubber on them
speaking of cars I had some fine ride (nissan xterra 2007) and I was so into cars and engines and rubber and everything about them, but all that changed after I smashed it, hence the name headon collision, so now I am into audio, gaming, pc, headphones, cuz their safer and cheaper, but I wouldn`t mind having a good ride parked in the garage.
Too up and close experiences can change a man's view of certain situations, I'll give you that. But we all learn from time and experiences, good and bad.
Just keep in mind that if you do go nuts over audio and computers, you can also spend nice chunks of money
