Just ordered these. Gonna see if they stand up to all the good reviews. Should get em on Monday
Creative Aurvana Live! Review and Mods
- Thread starter kingpage
Remior
- Mar 9, 2011
Cheap, confortable, light and portable, good bass (maybe soo much sub-bass), a bit punchy, nice mids, shy highs, good on a lot of king of music styles. Not a typical kind of V shape (more like a neutral U), no need amplification... It's a winner horse...
I hope you enjoy it!!
Just ordered these. Gonna see if they stand up to all the good reviews. Should get em on Monday.
mike1808
- May 2, 2013
Hello all CAL owners. Today my CALs have broken in my bag
I have broken a little metal bolt that connect 2 parts
Does someone face this problem? Can I glue it? Or I need to make a new one and replace the broken?
garcsa
Member of the Trade: Mandarines IEM Memory Foam Eartips
- Mar 23, 2011
Show me some photo, I'll help you.
Hello all CAL owners. Today my CALs have broken in my bagI have broken a little metal bolt that connect 2 parts
mike1808
- May 2, 2013
Here is macro photos
https://www.dropbox.com/sc/uvlsj581qx4r333/F8ArJqYVeQ
https://www.dropbox.com/sc/0yscmncrouzakm6/Wi2LCqAz7A
As you can see I have tried to glue them with superglue, but it doesn't keep it.
I am thinking about epoxy. If it doesn't work I will try to find man with milling machine and ask him make this detail. And if it doesn't work too I will try to find some screw with the same shape
garcsa
- Mar 23, 2011
Yep, the superglue can't help here. The strongest glue for this type of damage is Pattex Repair Express - IMO.
Suppose there are another type of this glues , too, but I like this one. 2 component - and its really strong. Hope this helped.
mike1808
- May 2, 2013
I used that type of glue very long time ago but for my bathroom. I dont think that I can it use for such a small thing.
And risk of that I cant repair it after failed using is very high
garcsa
- Mar 23, 2011
OK, best wishes...
cookie42
- Aug 15, 2010
Hi Mike,
I relaize this is a couple of months down the road - hopefully you have solved your problem. I actually just got the same exact break on my CAL headphones. A real shame. I think it is partly because I made wood earcups which are a bit heavier than the stock ones. I have contacted Creative and they seem to be pretty on the spot. I am trying to see if I can just get a whole new cup-swivel arm from them... with a downed warranty . I will keep you all posted. I'll post pictures if asked.
Magicman74
- Jan 16, 2012
I've got a set off a silver Denon Ahd1000 if you don't have any luck with Creative.Hi Mike,
Cups as well!! Oh a Driver as well!!
cookie42
- Aug 15, 2010
WOW! MagicMan, I did not realize that the denons were so similar to the creatives! Looks like the exact same drivers? Cups are almost the same, and looks like the same swingy arms.
So I contacted customer support and yea I don't have a warranty (got my unit off ebay for $50, and I've opened them up and resoldered em so many times that they would look at them and laugh) but they also said they can't just dole out/ sell individual parts. They offered me a 10% discount on any non-newly released products (ie can't use to buy some CAL2s) because I said I loved their products. Anyway, here's what I did:
I pulled apart the ear assembly that allows the headband to click and slide into place. It is comprised of two plastic pieces, the metal headband arm, two little metal pieces that slide and hold the headband in place, two glasses-sized screws, and the bolt that normally holds the earcup and allows it to swivel. The bolt that holds the earcups and swingarms inplace had split in two (my right earcup no longer attached to the headband). I took the swing arm, clamped it in a vise, and forced the broken bit of the screw (in the swingy arm) through the plastic by pushing it with a drill press *carefully*. I then found a similarly sized screw and ground it down til it fit in the head band portion of the assembly and it was the right length. Rest assured that when you take apart the headband assembly you can get everything back in place, it will still fit back together. Just be careful! Once I had the new screw in there and the headband portion reassembled (glasses screws in and all), I filled the new hole in the swingyarm with epoxy and screwed it onto the screw until it was back in place flush with the plastic portion of the headband. I then cleaned off the extra epoxy and let it sit for a few hours. Came back and put the cups on and it is rock solid. Well - the arm will never again rotate because it is epoxied into place, but the darn thing won't break again!
I should have taken pictures during the project but I got too absorbed and forgot. I will post a pic of my headphones tomorrow.
-cookies42
-cookies42
Magicman74
- Jan 16, 2012
Yes the Cal And Denon are basically the same set of cans. Basically, The differences, the Cals Cups are two pieces, the Denon is a single mold. The headband is different, The Cal is a solid band where the Denons have a wider pad at the top, Better padding. The cable is different as well, The Cal has that cheaper rubber and the Denon is better, Rubber as well but the plug is much higher quality. Also the pads are different, both the same size, but the Cal is a little thicker and memory foam. The Denon not as thick but is made of the nicer Fake Eggshell leather.
Also the mesh inside the Cals pads are thicker giving them a slightly darker sound, and the deeper bass. The Denons have slightly less bass but the Balance is better from top to bottom.
The drivers are exactly the same Foster/Fostex Oem.
I prefer the Denon, it has a cleaner more crispy sound then the Cals. Some people prefer the Cal for the deeper Bass, it gets muddy too much for me. Yeah the Denon is lighter in impact, but the rest makes up for it.
Glad you got your up and running, Glue/Epoxy works wonders
cookie42
- Aug 15, 2010
Hi MagicMan,
Thanks for the response. I have heard about this fabled "Fostex/Foster" driver elsewhere, and I was wondering what the hubbub was about. Now it comes to me I am thinking I was reading a post about the new CAL2 and CAL Gold / Premium or whatever that Creative is about to put out. The consensus seemed to be that a certain driver (Foster), and it sounded like even a certain model, would be desirable. Now, I don't know all that much about headphones. But why is Fostex apparently a cut above the rest? Is it a price and quality type of thing? Is it related to hype and fan-boy ism?
Thanks,
cookies
My CAL! envisioned below. "L" is the damaged side that will never move again. I made the cups out of brazilian cherry, jatoba. I just copied the original cups in terms of shape and made up some routing forms. Then I stuck my pieces cherry to the forms and routed em with a simple router bit. DOn't remember the size. I def could have made the things smaller (used a smaller routing bit and less wood) because these things are pretty big and weighty, even after hollowing them out. I tried to solder up some new wires (starquad) with a new jack but I simply do not have the skill to do it apparently. I could not solder it all quite right, or I would end up splitting a wire or breaking the cable.
Thanks,
cookies
Hi MagicMan,
Thanks,
cookies
Nice work.
cookie42
- Aug 15, 2010
Thanks! Pretty neat and easy project.
