DDDamian
- Jul 2, 2013
^^ this
No, it doesn't work like that. A volume pot is a divider - so at 'half' the volume knob, approximately half of the source voltage gets through, regardless of the value of the pot. Using a different value pot doesn't just mean you can turn the volume down more or less.
The only difference would arise if the pots have a different attenuation curve. But unless something is borked, or one was audio and the other linear, there will be no difference.
I have so much penis envy for your crack, that is the most beautiful wiring I have ever seen, well done.
I am just curious how much of an effect that volume pot has on the sound over the stock one, it does look a lot better, but does it sound better?
The same question goes for the tube sockets.
But good job on the crack, it looks great.
What would the different affects of a 25k, 50k, or 100k pot be on the system then?
I'll venture a guess that it changes the input impedance of the amp to 25k, 50k and 100k respectively. I'd also expect it to have some effect on the input tube since the pot acts as both a grid stopper resistor and grid-to-ground resistor.
Did I just score a Western Electric 421a for $175. It tested results at bottom does it look great test wise?
If it is not a WE421a it will be Tung sol 5998 clear top from the early 50's I think? I have a couple and they look identical to my WE421a I actually prefer the clear tops and find them a bit more musical and noticeably different to latter silver topped 5998's .
Going to keep doing some tube combo shoot-outs to see whether I'm going to install the speedball in my new build or not.
I had to buy 10 pcs minimum and I've only got one Crack, so I've got extras if anyone is interested.
I posted this on the Bottlehead forum, but there seems to be more activity here so I thought I'd repeat it.
This thread (http://bottlehead.com/smf/index.php?topic=5989.131) on the Bottlehead forum describes methods to mod the Crack to optimize bias for various tube types. I had added a switch and resistors to allow use of the 12BH7 as well as E80CC/5687 but wanted something neater and consequently more reliable long-term. Here's the before shot:
I decided to make my own PCB, integrating a DPDT switch and resistors, and condensing the dual boards into a single PCB.
Here's the bare PCB:
And stuffed with parts:
Installed in place of the 2 separate boards:
The first try wasn't perfect, as the mounting holes needed some dremeling to allow the PCB to clear the standoff from the other PCB. Also some of the pads are on the small side and the holes for the LEDs are too large, but it did work first time.
After spending more time switching between the 12BH7, and 5687, I find that the 5687 excels in imaging and placement, but is down on bass compared to the 12BH7.
