Nic Rhodes
- Jan 17, 2013
I bought my T1 for £400 on ebay but many examples at £500 - £550
Hi,
After you did the headphone jack mod did you do a voltage reading and did you noticed any voltage changes from the previous reading you have.Mine some went up 10V and some went down 3V.Thanks!
I did noticed some voltage changes in some readings, didn't write it down so I didn't remember but all were very slight around 1-2 V, and as far as I know as long its in the 10-15% range its ok, the only drastic change was that terminals 6 and 10 are now grounded and in the resistance test the result is 0.
May I know why Modi?
My 2 candidates were Modi vs ODAC, after reading and asking quite a lot about them I decided it that I might not like how the ODAC sound, I like the modi's looks and price, the crack build and the headphone emptied me from cash
I can see in your signature you have the Modi, are you asking that because you don't like what you got?
Mostly
Ok, moving forward!
If one would compare T1 and HD800 on Crack SB?
Are both of them significantly better than T90 and HD700?
Ok, moving forward!
Yes, they both are significantly better than T90 and HD700.
For those of you who upgraded the Electrolytic to Film Caps how did you guys attach those big caps on the plate and what materials did you used?I have 2 Mundorf 100uf 400V film Caps that i need to install,these things take up a lot of space.Thanks!
Ok, moving forward!
You can buy various adhesive tie-downs like this one - you'd need a longer cable-tie that the one shown though. One small recommendation is to mount the anchor point in advance and give it some time before attaching the weight of the capacitors so that the adhesive can really grip to the chassis plate before being pulled on.
Get both of them and you're more than ready to rock all night with your Crack
Agree that T1 is superior to T90. Can't comment on HD700, but the T1 with the Crack is simply outstanding and may be more enjoyable for many than the HD800 despite HD800's technical superiority. T1 is just such a good balance of technicality and musicality
I don't know what is your sound preferences but I would pick ODAC anytime. Modi is a good DAC for it's price but IMO ODAC is better. I did post about my impressions for these two DAC few pages back. But I damn agree Modi looks better than ODAC.
BTW, I understand how your wallet become thin in short time. Lol...
