trentrosa
- Jan 27, 2013
Are you 100% sure you don't have a loose connection on the socket, or elsewhere? This is the most common cause of the issue you describe.
You can also tighten the socket connections by gently prying the pin forks together a bit in the socket.
Several builders have had issues in their Cracks from "high quality" teflon sockets, so I wouldn't recommend them.
I've resoldered the joints twice and the tube is still sensitive to positioning so I'm going to try and replace the socket.
