Sonido
- May 18, 2013
So... I just ordered last night. How long is this thing going to take to get to me?
A couple weeks. In case you didn't know: http://bottlehead.com/bottlehead-kit-delivery-status/
You're one to talk!! I've been watching your post.
Getting very close to Crack heaven. Just a few more days.
I have just finished this Bottlehead Crack. Default cabinet with three layers of chestnut wood stain, five layers of spar varnish with 400 grit sanding between and a polish of the varnish after a week of hardening.
The panel has been spray painted with 8 layers of hammered dark grey paint.
I'm going to install the Speedball kit this week, along with two Mundorf 100uf 400v. In a day or two I will post a link to my blog with lots of pictures and detailed description.
Hope you like it.
Btw. there is a little distortion or maybe sibilance on the highest notes (above 9-10 khz). Is this because the caps aren't burned in yet? It has only been used for 2 hours.
I replaced my pot yesterday and I'm little disappointed ,swapped stock pot for Alps Blue Velvet and things got a lot quitter is this normal ,is there burn-in period for this pot ??
There seem to be mixed views on the Alps Blue Velvet. There are apparently some cheap knock offs about. Did you get your channel imbalance sorted?
I was blown away by the Valab stepper, the difference was very noticeable has anyone else tried this?
