ben_r_
Chisel tip is what I recommend and just tinning the tip with solder should be good enough.
Do you guys recommend a pointed or flat solder tip for the Crack (without the speedball)? Also, I heard someone on here recommend this tip tinner. Is this something I should look into? Or is just tinning the tip with my solder good enough? I have the WES51 solder.
