- Mar 4, 2013
Honestly lead-free solder is pretty horrible. solder with lead is so much more easy to work with.
Edit: Let me clarify lead free is a lot harder to work with but not atrocious. if you have something against lead than you won't have much of a choice. Also its honestly not any more unhealthy to use leaded solder as the fumes that come off are boiling rosin not lead fumes. Just make sure to wash your hands after.
I started out using lead-free solder, with and without silver. Leaded solder was a revelation, and I found I much prefer 63/37 over 60/40. FWIW, I like Kester 245 better than Kester 44. The difference is that Kester 245 has a no-clean flux core, which is better if you do any PCB soldering.
