lextek
- Oct 22, 2001
Time for some morning Crack and coffee. Best way to start the day.
Check out eBay international - One ending in the land of Oz in about 18 hours currently @ $120.00 US (76 GBP)![]()
I'm using the Modi with my Crack and HD650. Have you ever heard the Modi? If so, how would you compare it to your Bifrost? I'm planning to upgrade the DAC to the Bifrost, but I'm not sure if the differences are worth the premium price or not
Thanks,
Kratos.
Kratos,
I know people will disagree, but in my experience all DACs sound the same once you (a) get over the $100 price point, and (b) equalize for strength of output signal. I have a $1,000 DAC, I have several $300-500 DACs, and I have two $100 DACs. In a blind test, I don't think I could tell the difference between any of them, there are a lot of things you could spend money on rather than a DAC and get bigger improvements in sound. YMMV
Best regards,
Adam
Kratos,
Best regards,
Adam
Hi Kratos
Did you decide on getting a GEC 6AS7G brown base? One just finished for well under $200.00 - Was this you?
Cheers
Hi Adam,
Really? Actually this is the first time I've heard someone saying that there is NO difference in sound quality when you change DACs, my experience is different, I'm not as fortunate as you, I can hear the differences between DACs, I guess you can save bunch of dollars thanks to that![]()
Which equipment should I spend money on to get big improvements in your opinion?![]()
Thanks for your reply,
Best regards,
Kratos.
Hi WOlfdOg,
No, after receiving some recommendations from Adam here and in Bottlehead forum, which I guess you read also, I decided not to go for the premium tubes, and I'm gonna save pennies for the coming BH DAC![]()
Best,
Kratos.
P/S: I'm really jealous with your huge tube inventory by the way![]()
Buy the best headphone you can afford, first and foremost.
It's finished and on it's way to my Crack!![]()
My first significant tube purchase (i.e. >$50). I hope it will be a nice upgrade over my existing GE 6AS7GA which sounds brilliant with Genalex Gold ECC82 and driving my T1s.
