Brian Oneal
has any one else had an issue with the player updating media database every time the player is started. Is this a known issue, or is there a fix?
So when can we get the next Plenue D?
It has been two years now since the Plenue D was released. Hopefully we will see an update soon from Cowon with some more up to date features like bluetooth.
Exactly, love to see more capacity for this unit, you'd think they could fix this with some firmware update, tried the 200gb card but no go....and the ability to fully use 200GB and 256GB micro SD cards.
In order to fix it you will need to delete the songs from the Plenue D with the incorrect tags and then reload the songs with the corrected tags.First time poster: By way of introduction I'm coming from a Cowon D2 which I flashed with D2+ and then rockboxed it. Just love Cowon. But all good things must come to an end so I have semi retired this unit and replaced it with the Plenue D. And quite impressed with the difference. I'm still waiting for a new pair of IEM's to arrive so not fiddling with JetEffect too much at the moment so just spending time navigating around the features.
So, to my first question. How do I clear out / refresh the tags in the data base. I have a couple of albums with artists tagged "Florence and the Machine" and another Florence & The Machine". So I ended up getting 2 FOTM in the Artists lists. I have cleaned up the tags using MP3Tag and got the Artist saved exactly the same in all albums. But when I restart the PD and the data base refreshes it seems to hold the old tags.
I'm sure I'll have more question later on but loving the PD so far. I'll post my impressions a bit later on once I'm a bit more familiar with it..
Thanks - trying this method now and it is working. Taking a while though as I try to find the Albums, cut / paste them out of PD and then cut / paste back in againIn order to fix it you will need to delete the songs from the Plenue D with the incorrect tags and then reload the songs with the corrected tags.
Thanks. Will try this next time - looks like a quicker methodDelete the contents of the folder called MusicDB ( F:\System\MusicDB ). The database update will recreate them.
It is a strong little device, i like my PD, i was looking at others as well, but as far as i can tell there are none with dual slots for micro sd's, i see 128gb on board but would still like to see dual slots, but as you just stated if the PD sounds as good as the TOL then no need for me to bother, as i have enough to choose from in my on collection, but there's no disputing the battery life out of this little sucker.I heard the whole Cowon line 3 hours ago.
Same track on all devices P2 PM2 PS PD PM P1
This cheap little thing sounded as good as the flagship. I was interested in the P2 actually. I just read this thing doesn't have a true dac? Makes no sense. Sounded awesome.
