Dec 27, 2016 at 5:00 PM Post #3,812 of 4,971
  Hi all. I just got a second PD and it came with firmware v1.15 installed. Thought that was interesting because the last update I did on the other one was 1.14.  And now it jumped to 1.17 with no .15 or .16 on the website?
1.15 is a firmware for France only. Cowon had to update it according to the French law because the Plenue D was too "powerful" (too loud basically). It basically limits its loudness so it's not wise to install it.
I've stayed on 1.14 on my Korean unit and about to update to 1.17.
Dec 28, 2016 at 9:20 AM Post #3,814 of 4,971
Installed it but doesn't seem to make any difference. In the changelog they say it addressed an error parsing the genre tag.
Tag delimiters in genre still not working unfortunately.
Max. volume seems about the same as before the update. All settings incl. BBE+ still intact.
Cheers!
Dec 29, 2016 at 4:14 AM Post #3,817 of 4,971
  Hi , there is no such thing like queue feature but you can add your fav songs to the playlist and you can create 10 different playlists
Thanks for the info! I guess it's similar to Sony A Series bookmark feature. And it's good to know that you can create playlists on the go from the device itself, would be rather troublesome if you need  to use PC to create new playlists.
Dec 31, 2016 at 1:09 PM Post #3,818 of 4,971
Hey all,
I juts got my PD from advancedMP3players yesterday and I already have an issue with mine.
My PD while turning on just says "Reseource Load Fail" without an SD in or it gets stuck on Database update with the SD card in.
I've tried doing the dual volume button reset but that doesn't work.
It was working fine yesterday, I put a few albums on but after i tried formatting my Micro SD via Disk Utility (mac), this happened.
Anyone know a fix (or i'll have to send it back)?
Thanks for looking at this.
Dec 31, 2016 at 1:56 PM Post #3,819 of 4,971
  Hey all,
Might be an issue with your tags.  Have you a windows pc you could try formatting the sd card in just to see if that's it (or another card for that matter)?
Jan 4, 2017 at 3:04 AM Post #3,821 of 4,971
fwew.... after reading the 255 pagea of this thread I can't decide yet if i want the PD or not !!! my main setup is : galaxy S3>> digital out >>> RSA the predator dac/amp .. which i still love and probably is a keeper for life
i had walkman A15 .. was great but not a keeper . my iem is shure se535 and headphone : hd598 .
i am deciding between PD and onkyo dp-x1a i know it is 3times the price but if it vastly better i can hold and save some cash for it later if not would go for PD as my budget is limited already ! i am looking for clarity..sound stage .. neutrality ..as my predator is warm and very musical so i want some change in my daps portable devices
Jan 4, 2017 at 5:02 AM Post #3,822 of 4,971
clarity..sound stage .. neutrality...
Clarity - yes.
Sound stage - for me, excellent.
Neutrality - depends how you measure it, but I would say yes -  the multiple EQ options allow a wide range of customisation.
I haven't tried the Onkyo, and I am sure it's good, but the Plenue D is in a different league in terms of physical size and battery life.  Personally I'd find it hard to justify buying the Onkyo given the price of the D.
Jan 4, 2017 at 5:59 AM Post #3,823 of 4,971
Clarity - yes.
thanks for reply ... my neutrality and clarity  reference is the Walkman F806 ( if any one here used it before ) ... it was very CLEAR and forward sounding ... but a little under powered and the lake of hardware buttons led me to sell it hence the getting onkyo idea as it well known for its clarity and some finds it fatiguing .. yes the F was fatiguing too but i can handle it
Jan 4, 2017 at 12:05 PM Post #3,824 of 4,971
Hi:
First, let me say that while I've only had my PD for a couple of weeks, I like it very much.  Battery life is great, power is plentiful (although none of my IEMs or headphones are very demanding), and the array of EQ choices is amazing (bewildering?).  If you look back in this thread, you'll see that I struggled to get external playlists working, but did solve that problem, although the limitation that the playlist can only access tracks on the same device was a bit annoying.  In all, a great value, and likely to be my on-the-go player for years.
However, in 'Normal' mode (EQ off), I would not call it neutral -- rather, tending toward the warm side.  And I would call it more 'musical' than 'analytical' -- perhaps too close to the RSA rig you currently use.
BTW, I'm currently auditioning the PM2.  I'd say it has a very similar signature, slightly more detail with more definition AND depth in the soundstage, and an even MORE bewildering array of EQ choices.  Battery life is (to me) unacceptable.  In all, not enough delta to justify the price jump ($725 vs $200).  And NO playlist support, which is close to a deal-breaker for me.
My suggestion would be to buy one from Amazon and take advantage of the Prime return policy if you decide it's not for you.
Jan 4, 2017 at 12:53 PM Post #3,825 of 4,971
Hi:
thanks a lot for your reply ... the thing is i am from outside the US (Egypt ) , i don't have an account in amazon and i have to import all my stuff through intermediary companies and takes about a month to get anything from outside .. so it is one shot
 i have to choose wisely .. by the way i am not interested in upper models of Cowon ... D is the most appealing to me for the battery, design , price and of course the audio quality and BBE things i have to make sure that the sound sig is what i am searching for ... is there any D alternatives at the same price range that sound slightly bright and forward ? and can i change the sound sig of the D without being artificial ? as i love hardware equalizers not the digital ones and the only digital eq that i liked are : sony walkman eqs and their clear bass or the neutron eq which is so good too .... never tried Cowon BBE stuff
