Thanks for that I have looked back when I got it tried the setting didn't like them.
What do you set the frequency for each settings to With those setting you suggest?
Thanks
It depends on your IEM or headphone for everyone it will be different.
My settings with IEM's looking for accuracy:
80 Hz Wide +1 ~ +3 <Pick your + amount
385 Hz Wide +1 ~ +3 <Pick your + amount
780 Hz Wide +1 ~ +3 <Pick your + amount
4.1 Khz Wide +1 ~ +3 <Pick your + amount
9 Khz Wide +1 ~ +3 <Pick your + amount
BBE=3
MB=3
3D=1
MP=OFF
MP does add clarity but it also add sibilance at high volumes I noticed with some songs as does BBE.
Other settings I like are:
EQ Off
BBE=3
MB=3
3D=1
MP=ON
These settings are very slight but enough to notice, but if you have very detailed IEM's or headphones you don't need much of anything but again it depends on the music and the quality too.
Hope that helps.
