Kerouac
Will take a little while before I get to the review, as usual, got a ton of stuff on my plate. But can tell you right now after 24hrs of burn in and about 15-20min of listening, this AKM based DAP has closer to reference type of sound. This new AK4497 DAC doesn't have your typical smooth/musical AK4490 type of sound. Just based on my first impression, P2 has a smooth reference sound, like a crossover between DX200 and Opus#2. PM2 is warmer and smoother in comparison. As a matter of fact, with a number of my iems I like to switch JetEffects when using PM2, while with P2 didn't find the need for it.
Btw, interface is identical to PM2. It's all about the new DAC and volume and multi-function wheel. With those, my first impression is that I like being able to use a wheel for volume (and you can also use touch screen in parallel), but I'm still on the fence about multi-function wheel. I mean, great idea and you can assign different functions to it, but for now the only one which makes sense to me is to set it up as a 2nd volume control knob which has a coarse tuning (for a faster volume change 2 steps at a time vs regular volume wheel being "slower" with one click at a time).
New leather case is gorgeous, though I wish they would have cutout for hw control buttons. Not a fan of case-covered buttons because you can accidentally press the buttons vs when you have a cutout - buttons are recessed. But hey, just a matter of a personal opinion. Btw, I put it in my pocket, obviously volume-wheel down since HO jacks are at the bottom, and I had no issues with accidental volume bumps, though keep in mind, I'm wearing shorts, not tight jeans. Btw, P2 is small, even a bit shorter than PM2.
Love balanced HO, definitely a higher power output. Need to test more, but I thought the soundstage expansion was wider as well in balanced. Hissing with sensitive IEMs is very low, lower than PM2, much lower than LPG and DX200, and even a touch lower than Opus#2 - tested it with Zeus-XRA.
That's a gorgeous looking leather case indeed! I'm a bit surprised though that it doesn't have a cutout for hw control buttons, as the P1 leather case even already had that
Edit: just read your post on the thinner leather (protecting from dust) part after posting this.
So, I guess the only way to adjust volume in case the next song is louder/softer (I listen a lot in 'shuffle all songs' mode myself) than the former is to take it out of your pocket?
Maybe I'll pick one up later on (when prices have come down), for now I'm sticking to my 'old, but still going strong' P1
Thanks for this first impression!
