Music Alchemist
Pokémon trainer of headphones
- Dec 17, 2013
There is a difference between the Mojo and "any DAC". The line out of "any DAC" may or may not be very good for driving headphones since it is normally not designed for that task. The output of the Mojo can be used as a line out but it is also designed to drive headphones. For most other DACs this is not the case and hence they need an external amp. The Mojo doesn't.
Again this is really all semantics. Like you say, adding any amp to any DAC is in fact double amping in a sense. The point is that most DACs need it while the Mojo does not.
Yes, you can drive most headphones with it, but the point here is that connecting an amp to the Mojo follows the same concept as connecting an amp to any other DAC. It's just that you have the added bonus of driving headphones directly from the DAC's analog output stage (which does have parallel transistors), unlike most DACs. But some headphones cannot be driven from it. Electrostatic headphones, for example, require an electrostatic amp or converter, so you would have to connect the Mojo to one of those for that type of headphone. Some exotic piezoelectric headphones may also require more power than the Mojo can provide. And I don't know anyone who would want to drive a HIFIMAN HE6 from the Mojo alone.
The line out of "any DAC" does not have enough current to properly drive headphones since an amplifier is supposed to accept a line voltage input. Also, the line out of "any DAC" is typically in the hundreds of ohms in resistance which is clearly unsuitable for driving headphone transducers..
Just so we're clear, @Hooster, I was not implying that headphones can or should be driven directly from conventional DACs. I just meant that adding an amp to the Mojo is not really double amping, just as adding an amp to any other DAC is not.
Of course, under most circumstances, I would not want to add an external amp. When I did compare direct from Mojo to adding an amp, the amp always made the sound quality worse. (But this was only with certain headphones and amps.)
