iAudio365
- Aug 20, 2016
I use an audio quest optical audio cable to feed the sound on the back of the mojo from my Asus Rog motherboards built in supreme fx sound card.
What's a cheap (300$ and down) portable amp that makes that I can feed it mojo and the sound to be more dynamic and fun.?
You want to connect the Mojo to a cheap portable amp? I have an expensive desktop amp and the Mojo is so good that I would not even bother trying to connect the two. My advice is to enjoy your Mojo and spend the $300 on beer.
I feel that mojo is lacking in some. Mid bass slam and just overall dynamics. I prefer the dac portion of mojo as it's tech is nice but I'd like to alter its sound slightly with an amp to make it fun.
Ok, $300 amp to improve on the Mojo, more than can be achieved by simply increasing the volume of the Mojo a notch or two? Anyone?
I bought a Schiit Fulla (which I previously owned) to use with the Yamaha HPH-MT220 (without Mojo in the chain) to get a more exciting sound. But with most headphones, I vastly prefer the Mojo.
The thing is, the Mojo is going to alter the transients and dynamics if it's in the chain at all. That's why when I want a more obnoxious, in-your-face type of sound, I use the Fulla alone. (Oh, and the Fulla only has a USB input anyway.)
Not improve... Just change and make it more exiting... And not to just make it louder.... U missed the point.. Twice
Awesome, thanks. Usb input is fine how much is this?
Ok, equalizer like someone said, or headphones that are more to your liking.
I have an aversion to double amping, but don't let that bother you.
No double amping with the Mojo, there is no separate headphone amp built in to the Mojo. It drives headphones from the line-out stage of the DAC (like all Chord DACs).
Semantics. It amplifies the signal to drive headphones. It is an amp though you can say it is not a separate one.
Adding another amp is however double amping no matter how you choose to twist and turn it.
The headphone output can function as a line out to an external amplifier. Every DAC (well, aside from perhaps the MSB SELECT DAC II) has some sort of amplification inside to amplify the signal and send it to an amp. If adding an amp to the Mojo is double amping, then so is adding any amp to any DAC.
There is a difference between the Mojo and "any DAC". The line out of "any DAC" may or may not be very good for driving headphones since it is normally not designed for that task. The output of the Mojo can be used as a line out but it is also designed to drive headphones. For most other DACs this is not the case and hence they need an external amp. The Mojo doesn't.
Again this is really all semantics. Like you say, adding any amp to any DAC is in fact double amping in a sense. The point is that most DACs need it while the Mojo does not.
