Yeah the hissing problem with the newer units doesn't occur until the battery is 'full'.
The battery has to be at 100% AND powered on, i.e. in trickle charge mode.
From reading posts on here, it seems the problem is only with the QR coded units, the 2 I've been through are 46xxx and 47xxx. If you have an older 20xxx (or whatever) unit please do not post things like "I use the Anker charger, no hissing" as it's pretty much irrelevant, and only encourages people to waste money trying to fix this (it won't fix this).
Also post like "Just don't use it when it's charging" are not helpful, as Chord/Rob have always encouraged Mojo to be used this way, if the goalposts have moved it'd be good to let people know this before people buy this thing.
If I'm honest, I'm pretty disappointed with Chord's response to this problem, my experience was pretty much this.
Chord: "No it should not do that, we'll get it replaced"
Weeks later, still no replacement, Chord: "Actually it's normal, deal with it"
Me "This is lame, and because you dragged your feet I'm now out of returns period"
Chord "Ok, we'll replace it"
The new unit they sent still hisses whilst trickle charging, but (interestingly) it stops when music is playing. At this point, I'm begrudgingly accepting of that (as I suspect may end up with something worse if I get it replaced again), but I'm not exactly happy. It might 'only' be £400, but it's still marketed as an 'audiophile' product, the ONLY noise it should make is the music.
I suspect that Chord have a fairly large batch of these with this problem, and it seems they're more willing to stand by an 'audio' product that hisses than actually do the proper thing and recall the (IMO) faulty units.
