I have the mojo and was considering the 2Qute as my next step, because:
- i was considering the 2Qute as just a dac, to feed my preamp - so the lack of a headphone amp was not an issue
- the 2Qute has galvanic isolation, so is reported as an improvement on the hugo when using usb as the source
Unfortunately the 2Qute has a fixed output level of 3V, but my preamp can only cope with 2.75V - so this may be a showstopper for the moment. i am wondering about the hugo TT, but nothing is decided.
@boomtube
you need to be clear in your mind as to
what are your own needs/requirements (not other peoples requirements, because they can differ to yours, and shape their opinions in a way that means that those opinions are not relevant to your situation).
So clarify if:
- is sound quality the only criterion that you are considering? - maybe 2Qute wins on that score
- is the presence/abscence of a headphone amplifier important to you? - only hugo has a headphone amplifier, the 2Qute needs a separate amplifier
- is portability important to you? - if yes then only hugo is portable
- is usb your principle source (and so galvanic isolation is a benefit)? - 2Qute wins on that score
- if you want to use hugo or 2Qute to feed an amplifier, can the amplifier handle 3V?
- is bluetooth important? - only hugo accepts bluetooth inputs
- etc
Just compiling your own list of requirements, may identify which dac to chose very quickly.
