isquirrel
- Dec 29, 2012
whats the price range of the TT
The TT is AUS $6,400 versus the Hugo at $2,200
Too true. I used be on a photography group where definitions of "travel camera" ranged from really compact to 8x10 rigs. Even a light field camera (say a Linhof Technika) comes in at 3kg, before film, tripod, bag, lens, meter....
I made the point in a recent thread on Audiokarma - bemoaning the acceptance of the iPod and other 'consumer junk' - that to those serious about photography the point-and-shoot digital camera I own would be seen in the same light, and people taking photos with their phones might as well delete the images as soon as they've taken them. We see the world through the prism of our own obsessions - a terrible metaphor but its the best I can do. I used to drive around in a heavily modified V8 wondering how people could bear to drive such 'boring' cars - now I cant understand how I spent so much on a gas guzzler .....
any new gadget from chord coming out soon, that is portable ?
Did you hear about the Qute 2?
http://www.head-fi.org/t/749582/chord-electronics-2qute-dac-announced
Two things:
1) It is called the 2Qute
2) it is not portable (requires ac)
In portable application, how do you connect the Hugo to an outside portable amp? Through the pair of RCA? Or using the headphone out? It is my understanding that it is the same signal for all the outputs. So it is true that there is no difference between the headphone out and the line out (RCA)? Has anyone tried to compare the various outputs? One more question, if using headphone as output, do you control the volume using the Hugo or the external amp? Thanks for helping.
is the qute operated by battery as well, and if yes
would u consider the following setup ideal for portable use
ipod---qute2--alo mk3---audeze lcd2
I had a brief test with the Hugo and I liked it's sound but I still have some questions for Hugo owners:
1. Does it have on/off thump into speakers/headphones on power-up/power-down?
2. Does the volume control work without digital decimation at lower volume levels?
3. Can you leave it always plugged in without ruining the batteries?
4. What does a battery swap cost?
5. Does the crossfeed work only on the headphone output or it affects the RCA's too?
6. Output impedance for both RCA's and headphone outputs. Does it have different output impedance on some headphone outputs? - I looked in the manual and it only says the damping factor is >100 and they list the power into 8ohms so I presume it's under 0.08 ohms but I'd like to know the exact impedance.
7. Does the black version scratch easily? How thick is the "black stuff" on it - is the case completely black or is it just lightly anodized?
8. In my apt-x bluetooth tests when I set the HTC One down, moved two meters and put my body between the Hugo and the One, sometimes the music cut out ... how's your experience with the bluetooth range and stability with your devices? Was this because of the Hugo or because of my phone? Do you always have a stable connection across the room if there's no blocking or minimal blocking (people passing)?
9. Can you adjust the volume separately for the RCA's and the headphone outs?
10. Do you have to take out the headphones to use the RCA's or can you use both?
That's about all I can think of right now ... thanks.
