I had a brief test with the Hugo and I liked it's sound but I still have some questions for Hugo owners:
1. Does it have on/off thump into speakers/headphones on power-up/power-down?
Like any preamp, digital or otherwise I would never power on my amps first. If used as an amp I would keep volume low on power up.
2. Does the volume control work without digital decimation at lower volume levels?
The volume control is purely digital but at decent resolution. But at very very low volumes (i.e very low gain) you might get decimation. Rob, help here!
3. Can you leave it always plugged in without ruining the batteries?
Yes.
4. What does a battery swap cost?
No need to battery swap. No one has found the need yet. Can't imagine why.
5. Does the crossfeed work only on the headphone output or it affects the RCA's too?
All ouputs are parallel so all outputs are affected by volume, crossfeed, etc.
6. Output impedance for both RCA's and headphone outputs. Does it have different output impedance on some headphone outputs? - I looked in the manual and it only says the damping factor is >100 and they list the power into 8ohms so I presume it's under 0.08 ohms but I'd like to know the exact impedance.
7. Does the black version scratch easily? How thick is the "black stuff" on it - is the case completely black or is it just lightly anodized?
8. In my apt-x bluetooth tests when I set the HTC One down, moved two meters and put my body between the Hugo and the One, sometimes the music cut out ... how's your experience with the bluetooth range and stability with your devices? Was this because of the Hugo or because of my phone? Do you always have a stable connection across the room if there's no blocking or minimal blocking (people passing)?
Bluetooth range is poor, but I personally wouldn't use bluetooth for music audio, just as I wouldn't use texting to write a novel. Wrong tools.
9. Can you adjust the volume separately for the RCA's and the headphone outs?
No. They are same output.
10. Do you have to take out the headphones to use the RCA's or can you use both?
You can use both, but are putting more load on. I wouldn't recommend it
That's about all I can think of right now ... thanks.
