obsidyen
The power switch sucks balls. It's so 90s.
Thanks kkcc. If no bypass, then the signal will go through unnecessary amp section inside the hugo, causing negative impact on sound quality... Isn't it?
By the way, how would you compare hd800 with hugo output versus wa22 output?
These fit and work fine.
http://www.audioquest.com/bridges-falls/big-sur
Amen!
Also read this post from Rob: http://www.head-fi.org/t/702787/chord-hugo/1830#post_10459450
After reading many recent pages, seeing a lot of newcomers, and the questions being asked, I think it's important to reiterate a few points.
Cheers guys
There is no Line-out bypass level. There is actually nothing to bypass. You can preset the output level by holding the cross-FEED (not FADE) button when you turn Hugo on. You can also adjust the volume to most suitably match whatever you're connecting, without any degradation to the sound quality.
Secondly, in this situation, with the design of Hugo, and because the Hugo's outputs are analog, it is impossible to add anything to the output and make it better in sound quality. Except for special cases where very hard-to-drive headphones need more power. And even then, Rob mentioned that Hugo should even be able to drive around the 115dB level with difficult loads. But especially any IEMs, and the vast majority of headphones will only see degradation with the addition of analog gear. It's math. It's not up for debate.
There is not an amp gain stage like you're used to. There's not a DAC section, then an amp section. The way it's designed, you're essentially listening straight from the DAC because of the FPGA implementation. In fact adding an amp is essentially double-amping.
Reminder of Rob's words:
"Now Hugo has a single active stage ... Note: there is no headphone drive. Normal high performance DAC's have 3 op-amp stages, followed by a separate headphone amp. ... (Hugo) is fundamentally simpler than all other headphone amp solutions."
"... there is not a separate headphone stage as such - its integrated into the DAC function directly. You can't remove the sound of the headphone amp from the sound of the DAC, it's one and the same."
An amp may drive something louder so headphones have more power, which will inevitably sound better if you need high SPLs. For most normal use applications, you cannot add to the sound of Hugo's output and improve on it. You are only inevitably and absolutely adding output impedance, interference, distortion, and lowering the S/N ratio, from a number of places by adding another pile of electronics and wire to the signal - in the form of an amp.
That's why there's so much disagreement on this around here, but you cannot improve on the quality of the sound off the output. Hugo is always more clean, controlled, and technically correct. Which isn't many people's preferred sound, which is totally ok. That's why we all have a billion different headphones, to suit taste, mood and genre. If you prefer recording your blue-ray disc onto VHS because it gives you that jolt of nostalgia (maybe akin to running your tube amp with Hugo), go nuts! Good for you. Nothing wrong with that. Just know that is what you're doing.
These "improvements" people are perceiving are colorations and distortions more align with what they are used to, or more aligned with their preferences. Sure, their amp may have more low end, because of an uncontrolled driver - that's exactly what you'd get. The "improvements" are actually, in almost all cases, inaccuracies, colorations and distortions added to the sound with additional equipment. "Texture" is actually more distortion. "Bass extension" is really an underdamped driver, etc...
Mathematically, you cannot add to a complete analog system and make it better. Unless there was something fundamentally wrong with the Hugo at the line-out. Which is not the case. The specs top most everything. And some specs by enormous proportions. You can't add a lower performing anything and make it operate on a higher level. And simply, there are inherent and inevitable flaws associated with attaching another box electronics of any caliber to the Hugo's signal, it is not the best use of the signal! But some people will dig the character it adds to the sound. And that is fine, as long as you understand that picking up any extra gear to add to the output is actually only adding flaws, and you're tweaking coloration. The whole point of hi-end audio is to get out of the way of the music. Leave it as simple and pure as possible. Adding loads of electronics in the form of an amp is the antithesis of this concept. An amp adds alot. It really does.
Kind of like the difference between a high quality brand new leather wallet, and one that's been run in a couple years in your pocket. The new one is not one you're intuitively familiar with yet. You're used to and familiar with the older one, it fits you, and it looks way cooler to you now as it bears your personal character, and has the worn patina. All those bars and hotels... Ok now this sounds like you're hooking up with your wallet, which Head-Fier's don't do, because their wallets hate them.
Maybe it's just my taste, but the sound is best thru my Rudistor amp with the Hugo turned on with the crossfeed button pressed, I guess this just means maximum volume (violet-white color).
I maybe was wrong thinking the Hugo attenuator was completely bypassed by this method (just from my listening impressions), but, no matter, it sounds great. Everyone looking for a DAC should get a Hugo (just sayin' ...).
So just to be clear, there's no difference between using RCA outputs and headphone outputs whilst connecting Hugo to active speakers?
