2a3set
- Apr 27, 2014
It saves the cost of NOS tubes, so mostly Hugo to passive speaker now.
The Audiophilleo AP1 & PP has arrived, initial impressions are that the sound has lost all trace of any harshness. The music arrives out a black background.
The cabling is a mess though, can I use a S/PDIF cable instead of going direct, any loss of SQ?
If its a slight tuning to perfection, roll some cables...i know its a taboo here but its fun if succesfully achieve the result you want
It actually sounds better with a longer S/PDIF cable! 1.5m is best.
Longer is generally better with S/PDIF Cables.
Also make sure you "burn-in" the AP properly (200 hours).
Despite what other people here are saying, the AP1 improves the sound of the Hugo tremendously IMHO.
It may be just the RF noise/Jitter reduction. Who knows!
I agree, its all about personal preference, if you tune roll to get the sound you like then whats the harm?
I am totally confused with this AP1 & PP thing, I have the Wieworld supplied USB running from my Mac to the PP and then the supplied USB black short cable from the PP to the AP1 is this the best way or should I run the Wireworld directly to the AP1 and use another longer USB cable to run to the PP?
Confused!!
