can you tell us if a short coaxial cable with one end to be 3.5mm end when we can expect it and for how much
http://www.custom-cable.co.uk/custom-cable-cc35-3.5mm-coaxial-cable.html
I'm sorry but in this case AK240 is a waste of money. If Hugo does the dac& job, then AK240 provides nothing to the sound quality. A much cheaper DAP or even a mobile phone with SD card slot will do the same job. AK240 is absolutely unnecessary if you're going to use Hugo.
Kinda makes you wonder what's up with that doesn't it?Incidentally, is it a bit unusual for there to be a thread this long and no reviews of the Hugo yet?
The Hugo sounded fine from the X5, which was a surprise. I usually don't have faith in using a TS connector for S/PDIF as it is far from 75 Ohms. Once I'm back home I'll sit down and have a listen with every input using all the sources and cables I have and see how I feel about the sound with all of them.
So far though, nothing has been bad.
I had tried using X5 and DX 90 to Hugo, both of them sounded congested and blandly densed compared to CLAS -db to Hugo.
Good morning ok guy. I have a fellow headfi bro that has the ak240 and an iPod touch . He is claiming the AK240 is way above in sound quality over the iPod touch. Can this be has anyone else here tried this combo in comparison. For me the iPhone 5 in use is about the same as the a desktop CPU combo Meaning really good. What I had the ak240 for a couple weeks I tried the combo. It sounded good but much better with my iPhone. Any thoughts ??
Al
I love the hugo so much, but my match using audeze LCD rev2 is not the ultimate to my liking, and I just figured I am a basshead as I keep pulling the sms by 50 cent headphones to feel the bass punch.
So which is the best basshead headphone that works with chord hugo, and I mean literally basshead headphones but better than sms by 50 cent, to have a wide soundstage, warm, and not shouty as I have and really hate irritaing highs and mids
Try adjusting EQ to boost bass with the LCDs, should be significantly better overall sound qual compared with the other pair...
