CosmicHolyGhost
Exhaustively burning holes in his wallet
- Jun 10, 2013
so far I have heard its super duper awesome & rival desktop Dac of any price
How did you come up with this conclusion?
There are impressions posted on this site which would lead one to arrive at such a conclusion. Also there are reviews around the web which make it abundantly clear that this is about as good as it gets.
Post some reviews, guys...please
Google search didnt return much.
think you'll have to wait about another week for Industry reviews... after the Bristol Show (not many Hugo's around)
hopefully Jude will chip-in with some more thoughts.
Just connected the Hugo to iPad via usb cck and using Onkyo HF Player to play DSD and hi-res flac files.
Native DSD sounded awesome, can't think of any portable device right now that can stream DSD to the Hugo except for idevices or a notebook. Probably be getting an ipod touch 64G to make this a more portable setup. I definitely prefer the SQ and battery life of this setup over AK120S>Hugo, maybe there will be Android base devices that can do this in the near future...
What usb cable did you use out of the cck?
I guess that I'm talking to myself here.. but you might want to know.. the Airport Express way, is not the way to go.. at least for now.. I have optimized the network setup, and it is quite good, but dropouts still occure now and then.. I've searched on the internet, and I found this:
"I believe there are issues with the stability of the clocks in the latest AEs. If you go over to the pink side, you'll read of problems that the designer of the M-DAC had interfacing an AE to it:
" First first Gen worked without Drop outs when set to High Bandwidth... With Gen 3 they changed the Chip set and its even worst then the first for Jitter performance - with large discrete jumps in clock offsets - these jumps throw off (unlock) any dac with decent jitter attenuation (Tight Lock Bandwidths) - ironically Dac's with poor jitter attenuation cope with the Jumps, but off course they have poor jitter attenuation..."
and here's a similar comment from CambridgeAudio, quoted on an apple support forum:
"Basically, the Airport does not output a smooth SPDIF clocking. Every now and then, the Airport will sporadically adjust its output clock to track the desired sampling rate.
These adjustments are very sudden and are the cause of the noises and/or drop-outs describe".
So I guess I'll go back to the shop with the Airport Express and get my money back.. the cable should be ok but I don't need it anymore.. maybe in a few months if next generation of Airport Express is better..
I've heard that the AppleTV is better.. but dropouts are reported with those as well.. guess I'll give it a try.. but best guess now is to use USB and the camera kit with my iPad / iPhone / iPod Touch and use Bluetooth directly to Hugo while charging the iDevice..
