Mconnect is the best IMO. I did use glider for a while but it hasn't been updated for a while and is now a bit buggy
Grateful for the indication. What are the practical advantages of Mconnect over the GoFigure quick player?
Does this mean that with Mconnect I wouldn't have to worry about creating playlists? Could he browse my music folders on the SD card? This is it ?
There are over 200 posts about mconnect on this thread, containing user experiences, which are probably worth reading before buying the app. For example this poster seems happy with the flexibility https://www.head-fi.org/threads/cho...on-1st-page-◄★☆.831347/page-714#post-14436658
Mconnect doesn't work in Airplane mode but does in hotspot so no playlists needed as you can browse your sd card. If you can afford a POly I'm sure you can afford the $15 app. Give it a try. I use it exclusively.
Hi @Vyyy We've made an update to Android Gofigure to improve the playlist display. It is now available in Google Play if you want to try this out to see if it has resolved your issue. Matt
Nice to hear these news! Thought today morning of that againand suprised to see your post. For the moment GOfigure at googleplay is 2019-07-19 version. Will chech for the update to appear.
Something to be aware of, I am having problems with mConnect on Android 10, I have contacted the developers who have yet to resolve this on mConnect version 3.1.7, it is however running fine on Android 9.0
Good evening, Matt, Recent update completely solved my issue. Playlist shows as it should be. I must say THANK YOU and your developers team who where able to reproduce it , see the couse and most important fix it. Happy to be a part in that. P.S do you know the actual issue there? Thank you very much. Next, playlist song list and track repeat would be very welcome
Thanks for letting me know. That's good to hear. Yes I'll add those other functions to the wish list to see what can be done. Matt
When is the Gofigure app updated to also include iPad support? (Rather than being iPhone app that runs on the iPad)
I don’t know if anyone can assist. I recently picked up the Campfire Andromeda Gold, and I am aware that they’re amongst some of the more sensitive IEMs. However I hear a lot of noise. Not so much hissing. But it sounds like communication interference. I’m sure I read that IFIs IEMatch helps. Can someone with a similar setup help and clarify?
Welcome to the club, I pick it up with my headphones as well. The only way to mitigate it would be to put the Poly into Airplane/Bluetooth mode once you have the playlist loaded. You do pick up some noise whilst you browse the SD card files.
