Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Discussion in 'Portable Source Gear' started by Matt Bartlett, Jan 5, 2017.
938 939 940 941 942 943 944 945 946 947
949 950 951 952 953 954 955 956 957 958
  1. Matt Bartlett
    Hi,
    If you contact support@chordelectronics.co.uk with your details including the serial number of your Poly then
    we will check the registration and send you a code for the Roon trial.
    As for the full product manual then this is now online as it is the only way we can keep it updated and correct
    for the latest firmware.
    Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
    https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
  2. Matt Bartlett
    All Polys we ship are on V2.0 firmware. However Mike is correct. You can check with your retailer and ask them to update it if it is on an older
    version.
    carapau and miketlse like this.
  3. vkvedam
    @Matt Bartlett I would like to share this recent observation with you and the fellow Poly owners here.
    I kept getting an error message saying 'SD card has been ejected' whilst carrying out garden work yesterday, Mojo-Poly was in 'Airplane' mode and kept in my pocket. I wasn't moving around vigorously either. I didn't experience this before and there seems to be nothing wrong with the SD card either. I had eject it and reinsert it to get rid of this error. Now I have been listening to it for the past hour and Poly is being kept stationary, no issues.
    Question is whether the SD card playback gets affected if the poly is not stationary?
    Thanks, Ven!
  4. Matt Bartlett
    Hi Ven,
    No the SD card should not get affected with movement. I can only think that something was pressing against the card in the slot so it was forcing it to break connection
    and give you the error message.
    Matt
  5. Vyyy
    To add to this, i also have this problem. It happens then i use airplane mode and for example go to a different location with my phone and leave mojopoly behind. After 10-20mins i return and my phone and mojopoly dont connect in the app. If i press play to continue music, i get this SD card error too. Problem is i think Gofigure cant reconnect after some time with mojopoly (if a phone went to far). Or only on ANdroid it happens. Please @vkvedam what OS you use. I am sure 99percent that is Android :)) Ok, not sure but gues.
  6. vkvedam
    Yes, Android 9.0
  7. Vyyy
    Android 9.0 here too.
    Could you please check if a large number of playlist on Gofigure after scrolling up and down is shown correct? Thank you. That is my major problem which doest not appear on apple OS.
  8. Matt Bartlett
    Have you got battery saver on? I believe there is a new feature in Android 9 to limit app access to resources after a period of time to save battery power.
    It might be worth checking the power saving features on your phone just to see whether this makes any difference.
  9. Matt Bartlett
    We are still looking at this. I'm traveling for the next week but when I'm back I will hope to have some answers.
  10. Vyyy
    THanks for advice. Battery save function was switched of (always is), but i found optimizing feature under settings so i have unchecked it now. Though i just tested it does not have any to do with playlists. Regarding reconnect issue i wil see in the future.
    Travel safe! And spread the news with Mojo2 :)))))
  11. Richardhoos
    Hello all, I appreciate reading this thread and have a question.
    I am considering buying a poly to go along with my existing iPhone—>mojo—>Gilmore Lite—>ZMF verite set up. I’m having issues with the iPhone recognizing the mojo as DAC, and would like to be untethered from the iPhone if possible (would still be streaming from the iPhone). I love the sound when I can get it to work, sometimes it does but most often I can’t get the iPhone to recognize it and have tried others’ iPhones and have similar issues so could be an issue with the mojo USB port? At any rate wireless would be preferable especially since I pretty exclusively stream from Qobuz.
    I’m not super technically included so the connection issues with the poly does worry me. In sum, given the above, is anyone familiar with streaming Qobuz (sans Roon) to poly over WiFi? Alternatively, should I just forgo the mojo/poly and just bite the bullet and get a dedicated more desktop Auralic ALTAIR or similar?
    Thanks for the help!
    Rich
  12. Pimsilveira
    I have a mojo and I use it to listen to flac and alac files stored on my iphone 6s plus.
    Does anyone know if I would notice any difference in sound quality if I used the mojo/poly instead (flac and alac files stored on a sd card)?
    Has anyone made this comparison?
    Thanks
    Peter Hyatt likes this.
  13. Peter Hyatt
    iPhone dac versus mojo?
  14. Pimsilveira
    No.
    Iphone+mojo (files stored on iphone) versus mojo+poly (files stored on sd card).
  15. joshnor713
    It's not a big difference (to me). I do think the sound is cleaner, like a lot of people here say (probably due to the lack of RF interference, which the Mojo is prone to). In other words, I don't think the SQ benefit is reason enough alone to drop $600-$700 on the Poly.
