Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Discussion in 'Portable Source Gear' started by Matt Bartlett, Jan 5, 2017.
850 851 852 853 854 855 856 857 858 859
861 862 863 864 865 866 867 868 869 870
  1. didge70
    No change in sound signature here.
    My Poly’s battery still drains more quickly than the Mojo and has always been like that.
    MikeRight and HugoBerg like this.
  2. Matt Bartlett
    If you charge both Mojo and Poly together from the same charger then it will take around 7 hours. 4 hours for Mojo and then a further 3 for Poly. These are approximate times as it will depend on the charge level to start with.
    The charger should be 2A but using a higher power charger will make no difference as both Mojo and Poly charge at a fixed rate to preserve battery life.
    If you separate both units and charge them separately then yes you can charge in around 4 hours.
    Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
    https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
    Peter Hyatt likes this.
  3. t1tan1um
    Hi Matt,
    Any ETR for when the server is back online for V2.0? (today/tomorrow, in aprox. how many hours?)
  4. doggiehowser
    OK I am getting quite exasperated by the upgrading process to v2.0
    Getting 1.0.41 was easy enough. Then I launch GoFigure and Press Update... and it quits (as indicated in the FAQ from Chord)
    But the P status colors never really change on my Poly. They are ALWAYS white to indicate charging when I have the USB charger connected. I do see some color cycling when I disconnect the USB charging but it seems to settle on red not yellow (and I know my battery is about 50% so that can't be low battery). 30 minutes later still nada. Still 1.0.41. No v2.0
    This is so frustrating
    AH crap - server is down. Just caught up with the last post.
  5. miketlse
    Thanks Matt for the explanation.
    For the future (including 2Go) is there any way for the server to identify multiple/duplicate requests, and then transmit an alert to owner about the duplicate download requests, then automatically cancel those duplicate requests?
  6. Matt Bartlett
    Yes we are working on that now to come up with a solution.
    miketlse, Peter Hyatt and MikeRight like this.
  7. lhau
    How about LDAC?
    Also, how about Chromecast support for us Android users......
  8. PrittiPoly
    Does Poly still function fully as a streamer on 1.0.41 or is t just a bootstrap to 2.0.0?
  9. umerfulo
    @Matt Bartlett are servers still down? Thanks!
  10. mashuto
    What about LDAC? I understand that aptx seems to require a hardware change, but I have seen a number of devices get LDAC after the fact via firmware including some very cheap low powered devices like the earstudio es100. And while I agree that wifi is obviously the better choice when available, it just isnt always for certain things, especially on android except for specifically the services that are supported so far, and thats it. Without an airplay alternative like google cast/chromecast to make other streaming more universal, having something like LDAC would likely be good enough. Don't know if its possible, but it would be most welcome and would really round out the poly and make bluetooth streaming a viable option. And I know for me that when out and about, it might even be the preferred method, as I would not need to hunt for wifi, or run a hotspot on the poly which would essentially turn off internet on my phone or a hotspot on my phone which is a bit of a drain on my phones battery, though not sure how much more of a drain it is than running bluetooth.
    And I just wanted to say to you directly, that I am really enjoying the update. As vocal as I have been in the past, this update is great, and really makes the poly useable again for me. I had a hiccup this morning where it seemed to die, but after a restart, its going strong, and its quite nice to actually be able to use it now easily without having to worry about whether the connection is going to crap out or it I will even be able to connect at all. Really glad you guys stuck with it. And will hopefully continue to do so. I would say I can definitely now see the promise of what I had hoped it would be initially.
  11. Matt Bartlett
    Yes Poly will still function normally on 1.0.41.
    PrittiPoly likes this.
  12. Matt Bartlett
    Thanks mashuto. We will take another look at LDAC but I can't promise anything. Like a lot of new technology we have to see how widely it is adopted before we invest in development. However I can see that quite a few phones are now including it.
    From memory when I last looked it would only work if the product was running Android OS but that may have changed now. Anyway it's something else to think about.
    miketlse likes this.
  13. Matt Bartlett
    Yes sorry servers are still down. I'll check back in tomorrow to give an update.
  14. PrittiPoly
    Thanks. As a double Homeplug brickee I have an ultracautious mindset.
  15. fmkuz
    Hi @Matt Bartlett
    When update server will be up and running? I would like to upgrade to 2.0
