Poly light always circle red, green, blue. 1 hour, 2 hours and still no yellow color appear. No sd card inserted, connected to the charger, .41 installed but impossible to upgrade to the new version. Any help much appreciated.
Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
- Thread starter Matt Bartlett
- Tags
- chord chord electronics mojo poly
- Jun 4, 2007
mines also stuck in the loop ' hello your poly is pending a software update, please eject the sd card and reboot..........'
done this many times already, even factory reset
any words of wisdom, or go to chord support?
thanks
thanks
MikeRight
- Feb 20, 2016
I am in the same situation.
First minutes the light dance. Then the mojo main button changes from off to red and the light dance in the poly light goes on.
Tried 5 times. No success.
Tried yesterday night and this morning, always the green blue and red colours for more than 5 hours and still nothing .
paul.tonnenberg
Formerly known as HugoBerg
A rogue who wonders... Chord once again has his incompetent fingers in play.
I stay on the old firmware 1.0.26. It make no sense to update to 2.0, and it is useless anyway. Essential stuff like Google Chromecast support is not even integrated! ...unimportant mumpitz, like roon what probably not even 10% of Poly users use anyway. BOOOOORING!
Matt Bartlett
Member of the Trade: Chord Electronics
thanks
Make sure your Poly is on charge and the SD card is ejected. Then press the update firmware button in Gofigure just once.
At this point Poly will contact the server to start the firmware download. This can take quite a long time. You know it has started the download when the P status light starts to flash all the different colours. Eventually the flashing will stop and you should see a solid
orange/yellow P status light. This is when the firmware is being installed. Wait again until eventually Poly reboots and you should see
the white charging light come back on.
headmanPL
Although Apple has had many updates to its phone operating software it’s under tight control and is basically one set of homogenous software. That unfortunately isn’t the case for Android phones It should be noted that there are many tens of different phones all running slightly different versions of the basic android software. We have endeavoured to make Poly work with as many of these as possible but some phone will never work. It’s generally the older and cheaper the phone the less chance it has of working with Poly. This if a problem of the phone software and is not really a problem with your Poly.
So my question is a little different. For someone who uses Poly on a phone without gofigure support, will it remain on 1.41 firmware?
Matt Bartlett
Yes it will although we are working on a patch to allow updating via the config switch.
Out of interest what phone do you have as we have updated Gofigure for Android to work with more phones now.
lawshredpower
After a couple of hours using the new firmware it's easy to tell there's been a major improvement. It's working much better. Thanks everyone at Chord! The update process did not went smoothly to me, but a thousand times better than some users here. That was a catastrophe and the company needs to sort that kind of stuff out for the next update.
Things need to still improve a lot on the 2GO. Still not sure if I'd want one if it's just a Poly that fits my Hugo 2.
- Jun 4, 2007
Thanks Matt
Done that, (again
still stuck in the loop, and as per other people post the app closes in iOS
also, my lights alternate RGB when I turn off, not really flashing, and the m status light comes on white for a while then off for a while
Hi Matt, thanks for all. What do you mean by this can take quite a long time: 1 hours, 5 hours? The night?. In case of the P status light continue to flash différent colours after a long period ( 10 hours for example) what we have to do? Thanks for your help. Cheers jmMake sure your Poly is on charge and the SD card is ejected. Then press the update firmware button in Gofigure just once.
fordski
Someone mentioned on here a while ago about connecting the Apple watch to Poly via Bluetooth so they could listen to music on the go without having to take a phone with them.
I can confirm that this does work with the latest firmware and is another interesting use case I hadn't even considered until it was suggested.
Hi Matt, that may have been my post, just checked it out this morning on my walk and it works great! Not sure it'll get used much but it's nice sometimes just to bring poly along and leave the phone at home...
Azirius
Whilst I would have liked to see Spotify Connect and Chromecast support, I’m of the opinion that support for HiRes supporters like Tidal, Quobuz and Roon makes a lot more sense for something like the Mojo-Poly combination. It’s for audiophiles and music enthusiasts, people who want the best sounding combinations. Chromecast/Spotify Connect won’t likely provide such possibilities.
all i encountered yesterday was brief hiccups--no speeding up effect. I think the breaks in iPhone hotspot connection are impossible to escape in a city like NYC. so much interference everywhere. a fire truck passed with the sirens on and the connection briefly stopped. a train pulls into the subway and the connection briefly stops. i think this is an iPhone/wi-fi problem and not a Poly issue.
regardless--no more speeding up!
Sweet. I’m just now using it as a Bluetooth receiver (from iPhone) on the subway ride. I deliberately left it on WiFi mode (in other words, I didn’t put it into airplane mode) and I’m not noticing any of the skips and 6sec WiFi connection clicks.
Matt Bartlett
Ah great. Thanks for letting me know. Glad it works for you now. It's a great solution I hadn't thought of before so kudos to you for suggesting it.
Total: 41 (members: 0, guests: 41)
