jark
- Aug 31, 2009
Does anyone know why the PLEX app on an iPhone doesn't give the option to use POLY as a renderer? the only option available is through Airplay which sucks (no highres)
BubbleUPnP will likely be the best one to use, given it's printed in the manual (then again, GoFigure is also printed in the manual, so take that with a grain of salt...).Android users,
If I’m going to make android videos, what player should I use (I don’t want to go down a rathole evaluating them all)
Android users,
I'm going to go out on a limb and say Google Cast capability will not happen with Poly until at least 2019.I don't know if its the same on iOS, but on android, I am pretty sure the plex app uses google cast in order to cast media. Plex the server can act as a dlna server, but that doesnt really apply to Poly, since Poly itself acts as a dlna server and renderer, and I dont think plex gives you the option to use dlna renderers. As far as google cast. The poly doesn't support it. Yet. I am referencing an old post from February, but https://www.head-fi.org/threads/chord-electronics-☆-poly-☆-wireless-microsd-module-for-mojo-☆★►useful-info-on-1st-page-◄★☆.831347/page-79#post-13265521 John Franks definitely said it would support it. It doesn't yet, so I am hoping it will be coming soon, along with actual spotify support (which is in the manual, but also doesnt actually exist). I think however the priority right now for them is fixing the remaining connection issues and making sure that what is there is solid before they start adding in the features that they said would be there.
After 30 minutes, it somehow turned on. Guess it became warm enough to turn on.
In case you missed it there is a subset of Mojos that have a slightly lower voltage presented on the micro-usb and the Poly is looking for a specific voltage. The Mojos perform perfectly as DACs but will not trigger the Poly. Chord wants to replace the Polys of people who are having this problem with new ones that they have changed to sense a voltage rather looking for the specific voltage. I have 100% confidence that Chord will look after us all and we will not be left with paper-weights. Before exchanging the units make sure that only the new updated Polys are in the supply chain as you could get the same problem again. Mine waited 40 minutes or more to turn on. You could always get it replaced under warranty.
I am sure that Chord are getting to the bottom of this and organising the remedy. Chord are a world class organisation and have provided a whole new set of users the ability to hear how good music can sound. They design with a passion for their work and not matter how frustrating we may find this as end users it will be nothing to the disappointment that they are feeling.
So how do you power this thing on actually?
Currently struggling for 10 minutes to get this thing powered on. Tried leaving the Mojo for 5 minutes on and nothing happens. Also tried repeatedly trying turning it on or off and nothing happens also.
Do I need to buy a heater for this thing to work? (Which I will not do ofcourse, that is silly)
