Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
Nov 23, 2017 at 6:29 AM Post #3,811 of 19,924
@Matt Bartlett hello Matt, when the GoFigure app is eventually released, will I still need a 3rd party app such as MPDluxe to control the content on the SD card? I just wanted to manage my expectations because I'm under the current impression that with the release of the GoFigure app, the setup and playback of Poly through it's various mode will be a seamless affair - by that I mean you just need one single app to do everything that the Poly is built for. is my assumption correct?
my main use case for the Poly will be when I am outdoors without a wifi connection so what would be the best mode for the Poly to be in, for the best sound quality? my Mojo and Poly are both ready for collection but since I am out of town, I will only have them in my hands in early December.
thank you Matt for answering my questions :)
Yes it will have a quick play mode that will let you play directly from the SD card inside Poly without requiring WiFi.
Nov 23, 2017 at 6:35 AM Post #3,812 of 19,924
My poly this morning when powered on showed a red battery status, with mojo at blue. I assume this is again the “smart charger” issue with Anker chargers.
@Matt Bartlett can you tell us whether this can e fixed in software, or post a link to a few preferred chargers you guys use on amazon?
Nov 23, 2017 at 6:39 AM Post #3,814 of 19,924
Nov 23, 2017 at 7:14 AM Post #3,815 of 19,924
I use an Anker PowerPort 5 with Mojo/Poly which has 2.4A max outputs and all is ok but I normally only use 2 ports - 1 for Mojo/Poly the other for my iPhone.
The output on the Anker is 8A shared across all the ports. If you use all 5 at the same time then you can only get a maximum of 1.6A which isn't enough to charge Mojo/Poly at the same time.
If Poly doesn't 'see' enough charge current then it will prioritise charging Mojo first.
The smart charge will only be an issue when both products are fully charged and the load current is so low the port on the Anker may shut down.
Nov 23, 2017 at 8:04 AM Post #3,817 of 19,924
I have a 60W Anker unit and had an Apple Watch, Poly and iPhone connected. For whatever reason poly was zero. Could it be it was "up all night" and when they reached 100% and stopped drawing power the Anker shirt down the ports and poly continued to drain? For the SW updates this would seem to be necessary (being awake)?
At any rate, the device does 12A and I had plenty of juice.... but this is a real problem.
"Advanced Charging Technology: PowerIQ and VoltageBoost combine to provide the fastest possible charge up to 2.4 amps per port or 12 amps overall (Does not support Qualcomm Quick Charge)."
(https://www.amazon.com/gp/product/B00P936188/ref=oh_aui_search_detailpage?ie=UTF8&psc=1)
Nov 23, 2017 at 9:04 AM Post #3,820 of 19,924
Not sure what you are asking here?
The power supply shuts down (to comply with environmental requirements) once it senses the load current dropping below a certain threshold. This is also a good thing for batteries, as it stops continually recharging the battery once it drops to say 95% capacity.
Each battery has a limit to how many charge cycles it can go through. I've had so many laptop batteries expire prematurely because of being plugged in all day and accepting multiple charge cycles.
I have 3 Samsung chargers that stop charging a Galaxy Tablet at 87%, no matter how long they are left on. They also shut down with Mojo or Poly. This means even if a device is plugged in while being used, the battery runs flat as the Samsung chargers don't wake up unless I physically unplug them or switch off and on at the wall.
The 2 Sony chargers I have, do not do this.
Personally, I can't see how a firmware update from Chord can change this as I know in my case that wouldn't change a thing with my Samsung chargers, and I don't know how it would alter your Anker. Even if it could, I wouldn't want it as I would prefer a longer life from the battery.
Nov 23, 2017 at 9:56 AM Post #3,823 of 19,924
I guess it depends on what it takes to wake up the charger. If the cable needs to be unplugged and replugged, then no update can address it. But if the Poly just draws too little current for the charger to see the need to wake up, then perhaps Poly could trigger some sort of high draw activity when it reaches 25% for example, causing the charger to wake up.
Nov 23, 2017 at 11:52 AM Post #3,824 of 19,924
I'm happy to hear Glider is working well for you. The current version from the App Store will not see your Poly when connected to the local hotspot network, but we've fixed that internally and are currently beta testing for a release soon. If anyone would like to test this out, please send me a direct message and I'll get you set up.
Hi Joe. I can't seem to send a pm with Head-fi but I would like to try the Glider beta with my Poly. Thanks.
