I’m very pleased with the Poly and with a few tweaks it will be pretty much bang on
Chord Electronics ☆ Poly ☆ (wireless & microSD module for Mojo) ☆★►USEFUL INFO on 1st PAGE!!◄★☆
- Thread starter Matt Bartlett
- Tags
- chord chord electronics mojo poly
jamestux
- Oct 24, 2015
@Mojo ideas
Hi John you mentioned that there was an update to Mojo earlier in this thread. Is there a way to get that applied to an early model, and if so is there any benefit to doing so?
Cheers!
Just off to pick up my Poly
Cheers!
Mojo ideas
Member of the Trade: Chord Electronics
- Oct 20, 2015
Well done james. The Mojos software is not accessible and cannot be up graded post manufacture.@Mojo ideas
Cheers!
@Mojo ideas
Cheers!
Just a change to outer casing.
Hi, a question for any 8 player users. Have you been able to get playback of AIFF files. I only seem to be able to play FLACS, not AIFF. Anything obvious I could be doing wrong?
Thanks
Still cannot get AIF files to play using 8 Player - anyone else had any luck?
Feedbacker
I've just converted a FLAC file to AIFF and you're right - the folder I put it into shows as EMPTY on 8player. I guess it doesn't work with AIFF?
keithmarsh
I had an issue where hardly any of my tracks would play when my iPhone was set as the output device (or the poly through airplay). But setting the output as Poly [renderer] in the main UI (not in the output options in play view) solved the problem for me.
I don't have AIF files but thought it might be helpful.
Can the firmware of Mojo be upgraded afterwards via the Poly, during a future SW upgrade? Has Chord considered this?
As already mentioned above the Mojo doesn't have field upgradeable firmware as for a "normal" flash upgradeable device.
The FPGA code is usually programmed using a special "JTAG" type programmer via a dedicated connection on the board. The FPGA image can't be distributed as an end user could then in theory obtain the image file and components and make their own Mojo.
Thank you for clarification!
Thanks - odd as it suggests it does - so puzzled. Need to look at an alternative player as all my files are AIFF and I would prefer not to get into converting themI've just converted a FLAC file to AIFF and you're right - the folder I put it into shows as EMPTY on 8player. I guess it doesn't work with AIFF?
With 8player you can play all the most popular media formats:
▹ Video (including subtitles support): avi, mkv, mp4, mov, mpg, vob, wmv, m4v, asf, flv, ogg, 3gp, etc;
▹ Music: mp3, aac, flac, alac, wav, aif, wma, etc;
▹ Images: jpeg, png, gif, bmp, ico, tiff.
Any other players besides 8 player I could use on my iPhone - with gapless playback too world be good ?
jamestux
- Oct 24, 2015
I assumed not!
It is sounding great, can't wait for the kids to go to bed!!
Does anyone know an android based way to stream dsf files? I only have a couple so it' not a biggy for me.
Also if anyone else is using it mobile are you setting your phone as a hotspot? Once I'm in the office I'l be fine but Im thinking about being on the train
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
Dieling
- Jan 9, 2017
Received mine and charged overnight. Set up so far pretty easy - a bit fiddly with the wifi, once I personalised the Poly's name it connected fine. Using 400gb SD card seemed to load ok with 8Player, but have not timed it yet. Tidal via Airplay - check. mconnect player (which has Qobuz integration) - Poly won't show up as a renderer.
Can Chord integrate with Qobuz?
Pleased so far.
More later.
Although Qobuz is not integrated, can you streaming to poly using Qobuz app via airplay?
jamestux
- Oct 24, 2015
You can stream Qobuz (including hi res) via bubbleupnp if that helps?Although Qobuz is not integrated, can you streaming to poly using Qobuz app via airplay?
Sonic77
- Dec 12, 2011
Unprofessional.Ah thankyou we’ve just got your enquiry I note it was actually posted and received by us a 11:38 uk time this morning ie a few minutes ago. Don’t worry we will try to read between the hissy fit and answer your questions to sort out your issues and get you up and running promptly.
Total: 12 (members: 0, guests: 12)
