Not in Roon mode. Poly tells me I’m in access mode. I can configure everything, and it seems to save it as well. But on rebooting the Poly doesn’t lock on any of my configure and saved ssid
Here's info from post 2 maybe it will help.
Here are some additional tips put together by Matt Bartlett Chord’s Manufacturing Director
1. Poly Lights:-
a) Flashing blue then green means Poly is in access point / hotspot mode.
You will be able to see a WiFi network called Poly to connect to and then use the
config webpage to make changes to Poly setup. Bluetooth will not function in this mode.
b) Solid light means Poly is connected to a WiFi network. The light will be blue when fully charged,
then green, yellow, red as the battery depletes. The important thing is that the light is solid and not flashing.
c) Flashing Blue means Poly is connected and playing via Bluetooth.
d) White means Poly is on charge.
2. To access the config webpage Poly must be in access point mode and the light must be flashing green and blue.
You will see a WiFi network called Poly followed by a number. Connect to this and the webpage should automatically
appear. If you don't see the webpage open any browser and type
poly.audio into the search bar.
3.
Poly hotspot mode can be permanently switched on. In this mode it will always use it's own internal WiFi router and will
not
connect to the internet or any other WiFi network previously stored. On the config webpage navigate to the Play mode settings
tab and check the tick box marked Keep in hotspot mode.
Note:- Hotspot mode is the same as access point mode where Poly will be broadcasting and connected using it's own internal
WiFi router so the lights will flash blue and green.
4. Phone hotspot mode should be setup in the same way as any other WiFi network.
Enter access point mode on Poly (flashing blue and green lights) and open the config webpage.
On the WiFi settings tab add your SSID for your phone hotspot and the password. Tick the reboot
on save box and the click the save button.
Note:- Make sure your phone name (SSID)
does not include any special characters like a dash or apostrophe.
So don't use the name Bob's iPhone - instead use Bobs iPhone.
On the iPhone you can rename your phone by going to settings - general - about - name.
5. If you are having trouble getting Poly to remember WiFi settings then make sure you tick the reboot on save box
before clicking the save button. This will force Poly to reboot and change settings.
6.
Apple Airplay will only output a 44KHz sample rate signal. This means the light on Mojo will always be red even if
you are playing a high resolution file. To play high resolution make sure you use a DLNA/UPnP app such as
8Player or BubbleUPnP where you can select Poly as a
renderer output.
7. Tidal on the iPhone will only output using Airplay or Bluetooth. On android phones you can use apps
like BubbleUPnP which include Tidal integration to play music directly to Poly as a renderer.
8. Checking the saved WiFi networks. On the config page is a tab called
Manage Connections.
This will show all the WiFi networks setup inside Poly. Here you can delete them if you want to.
Poly will automatically connect to all the WiFi networks listed providing they are in range and
then it will connect to the strongest first.
9. If you have your headphones or HiFi system connected to Mojo then you can make Poly
'speak' the mode and IP address it is connected to. Just give a short press on the config button
and you will hear Poly announce the settings. If you press and hold for more than 2 seconds then
Poly will say 'entering access point mode' and it will reset
