- Oct 6, 2013
So you will go for the Bluedio S3?
I can't decide between a chinese BT 4.0 unit like the S3 and a Sony SBH50 which is BT 3.0, do you think there is a difference in audio quality between 3.0 and 4.0?
There are dozens of these look-a-like bt headsets, and they are all the same re-branded junk that sounds the same. I get a lot of them sent to me for reviews, and I never even bother writing about it, all the same build and thin sound lacking bass and with rolled off highs. If you want something that's going to sound good, look for a new "breed" of these headsets supporting BT4.0 and aptX codec. That will be an easy way to weed out garbage. aptX codec uses different compression which preserves bandwidth. Not perfect, but noticeably better in comparison to other ones.
As a matter of fact, I just received and will be reviewing this one: http://www.amazon.com/iClever-Lightweight-Headphones-Microphone-Transmitter/dp/B00RF27R9I - it sounds excellent, has angled nozzle (better fitment), and very detailed especially with Spiral Dot tips. The only problem, and it's common with every single variation of these headsets, you get a driver flex. The shell is big, housing electronics and no other air vent besides 9 holes in the nozzle itself. So with a tight seal of eartips (you need it for the low end to come up), you will get air pressure going right into the dynamic driver causing it to flex. There is no way around it because of micro-usb charging mechanism, battery, and all the BT circuitry stuffed inside of these little shells.
