Pastapipo
ZuperDAC + Havi B3 Pro 1 =
Specially this song:
Thanks! Great song!
Returning the favour:
DD good for produce good Bass
BA better for clarity of details, such as mids or treble.
Single DD usually can't last you more than a 6 mths IMO.
Multi-BAs good but not exactly for fun
Single DD won't last more than 6 months? What does that even mean...
Do we know what the sound signature of the Master 4 is supposed to be?
I asked Zorloo for a full spec sheet and they emailed me a PDF with the relevant information, and it was there it was listed at 4 ohms. I emailed them to clarify it.
Here is what was in the PDF:
ZuperDAC Portable HiFi USB-DAC Specification
Hardware Specification
AudioDAC
ES9018K2M
Headphone Amplifier
ES9601
Connector
USB Type A Male
Color
Gold, Silver
Power Consumption
~70mA
Certification
CE, FCC, RoHS
UPC-A
841295100064 (Gold) 841295100071 (Silver)
Audio Specification
USB Audio
Class 2
Maximum Sampling Frequency
192kHz
Maximum Bit Depth
24-bit
Output Power (max)
25mW + 25mW
SNR
115dB
THD
0.003%
Channel Separation (L/R)
60dB
Output Impedance
4 ohms
Dimension border-bottom-width:.48001pt;border-left-color:rgb(0%,0%,0%);border-left-width:.48pt;border-right-color:rgb(0%,0%,0%);border-right-width:.48pt;border-style:solid;border-top-color:rgb(0%,0%,0%);border-top-width:.48pt;">
Length (mm)
46
[TR]
Width (mm)
23
[/TR]
[TR]
Height (mm)
10
[/TR]
[TR]
Weight (g)
16
[/TR]
Useful Information
Zorloo Home Page
http://www.zorloo.com/
ZuperDAC Landing Page
http://www.zorloo.com/zuperdac
Windows Driver Download
http://www.zorloo.com/download
Windows Driver Installation Tutorial
http://www.zorloo.com/tutorial
General FAQ
http://www.zorloo.com/faq
Where to buy
http://www.zorloo.com/shop
Contact us
http://www.zorloo.com/contact
I am not even sure how I would go about measuring the output impedance as I don't have the tools for it I would imagine. Perhaps you can point me in the right direction. Is your incoming iem an all BA or hybrid iem?
Nice! Thanks! The lower the better, as far as I'm concerned
I've never done it myself, but maybe someone like @HiFiChris
can give you some tips? I was going to give it a shot, but then my multimeter broke, so I never got around to actually doing it.. Given the tools I have(/had), I'm not sure how exact I would've been able to measure it, but I was sort of thinking about starting out with trying to measure something where I already knew the OI and see how close I got.. Anyway, I will have to get a new multimeter eventually, I might give it a try when I do.
When I was looking into information about methods I stumbled across threads like http://www.head-fi.org/t/739322/how-do-you-measure-a-headphone-amplifiers-output-impedance
It's a hybrid, 1DD+2BA.
A multimeter along with some adapters as well as resistors would be the most accurate way to calculate the output impedance for sure.
I'm doing it a little differently and measure source devices and amps in RMAA (if you use the search function, you should be able to find my thread where I have posted a tutorial on how to measure, then the output impedance can be approximated using a formula - I'm posting this from my tablet computer, so cannot paste the link at the momemt). It is less accurate than a measurement with a multimeter and resistors but (depending on the IEMs used for doing the RMAA measurement) precise enough to see whether the souece device has got a really low output impedance around 0 Ohms, 1 Ohm, somewjat above 1 Ohm or clearly above.
REVIEW: Vivo Xplay 3S + XE800 Mobile audio perfection
The ones on Ali that these guys are buying are real. The fakes don't have the rotating nozzles.
Sounds to me won't last me forever, if you had BA+DD hybrid IEM beside to you
Do you mean physically they won't last bc the driver dying or won't last bc you get bored of the sound? Either way thats a bunch of crap lol
Due the sounds easily get bored, if you own one and used forever, yes.
Cause you can't get compared to others.
Such as my TFZ S1 already sitting in dry cable now.
Even it passed 6 mths ago is my dream and wishlist.
Just now went to tried again, the sounds no longer impressed me
Either me already has a reference IEM such as banned here Dxxx
MY SUMMARY AND CONCLUSION
| Minor comparison an over the rest. IF you asked me about the xxxx D2 vs S1, they are quite similar Bass boot for both has a such good hi-definition of sounds quality and clarity of detailed. IF you talk about the Treble wise, i will prefer an over S1 Now it no longer impressed you ? Mmmmmm |
from yr web page on TFZ S1 ( copy n paste )
THE ACTUAL S1 LOOK
S1 has a great soundstage,
Very smooth Mids, quite close to BA driver.
Pretty sweet treble, no harsh, fatiguing orpiercing an issue.
S1 Bass has solid energy and punchy bass extension like QT5/D2.
S1 has huge bass and speedy of bass.
For me S1 is a great IEM and value for money, very huge soundstage and sweety balanced sound signature to enjoyable such as Rock, R&B, Female vocals or even Jazz as well.
[tr]
- Fitting really comfortable and pretty great sealed, cause of the design are 45 degree of the nozzle for better insertion to your ear canal, there is no sound leaked an issue.
- My recommended for comply T200, will be perfectly fits.
- Very light weight shells, there is no such uncomforted it as longer period, cause all the rounded shaped, i am loving it so much.
- S1 has the truth balanced sounds signature to enjoyable more for any songs as what you listening.
- The downside be the cable come non memory wire and the rest was perfectly.
- The overall were highly recommended
[COLOR=546270]
[/color][/tr]
IF you asked me about the DQSM D2 vs S1,
its one of the best single drivers ive heardshozy 0 is amazing
