Thanks. Then they would be my suggestion.I see them for as cheap as 90 USD on Shopee and Lazada
CHIFI LOVE Thread-A never ending IEM-Heaphones-DAP-Dongles Sound Value Quest
- Thread starter NymPHONOmaniac
unifutomaki
I think the saving grace of the X1 is that regardless of whether you like either of the tuning choices, it takes EQ like a champ. I thought that the best way to make the X1 work for me was to do switches-down mode and add warmth, but it may actually be more sensible to leave it in switches-up mode and cut the bass, since that allows one to take advantage of the dual dynamic driver design.
This is a purely ear-based assessment, but I think the main reason for vocals sounding wrong in the switches-up mode is that there is a section of the midrange where the 10mm and 6mm drivers overlap in their response, resulting in the otherwise clear and resolving 6mm driver becoming drowned out by the vague thumping and booming of the bass-tuned 10mm driver. With significant EQ (like the settings I posted most recently above), one can cut the prominence of the output from the 10mm driver in the mix and achieve a linear response from the bass to the upper mids (pinna gain notwithstanding). After EQ-ing the X1 in switches-up mode, all the bloat and darkness is gone without having to ask too much of the 6mm driver, and the additional sense of dynamism (from having the two drivers working together) is restored too.
So, the X1 then... still my mids and vocals benchmark set at the $50 mark, and something you can probably make work for your own personal tastes. Just be prepared to fix the tuning yourself, but at least it is possible to do.
JEHL
So I think the TRN TA1 ties the Jade Audio EA3 for the cheapest hybrid using the Knowles RAD-33518.
Wonder if TRN will attempt to make it a mild V-shape like the IEM it's inevitably compared to.
Also from what little I could read about it, it appears that the 8mm DD is used exclusively as a woofer while the BA does midrange and treble. No idea how single DD single BA hybrids are usually crossed and for all I know everyone does it differently.
unifutomaki
Switched back to the Tennmak foams on my X1 (switches up, bass cut EQ) and gosh it sounds sublime now that both drivers are doing work. The warmth and weight has returned, serving as a backdrop for the transparent and resolving mids without getting in their way. Toggling the EQ off and on makes the X1 sound like two completely different IEMs; one unlistenable and the other exactly what I wanted from a mid-centric set.
Next acquisition will probably be the Heart Mirror, at which point the X1, SSR, SSP and HM can get into a fine old scrap to decide which ~$50 neutral-bright transducer is best
(for the record, the SSR and SSP still beat the X1 in terms of technicalities; their drivers are faster and tighter, however the tweaked X1 is the clear winner for me in terms of tonality).
1clearhead
- Apr 5, 2013
Hello fellow head-fier’s, my review for the MT300 in-ear earphone is finally here!
Link: https://www.head-fi.org/threads/chinese-asian-brand-iem-info-thread.820747/post-16184539
Enjoy!
-Clear
Enjoy!
-Clear
Jitu13
Baskingshark said that HM is technically superior to ssr.Switched back to the Tennmak foams on my X1 (switches up, bass cut EQ) and gosh it sounds sublime now that both drivers are doing work. The warmth and weight has returned, serving as a backdrop for the transparent and resolving mids without getting in their way. Toggling Direct Source on and off makes the X1 sound like two completely different IEMs.
Also eagerly waiting for your royal rumble results.
The tuner of TRN TA1 had told me it's a warm and bassy sounding signature. I will have it compare to another 1DD 1BA hybrid of 2HT.So I think the TRN TA1 ties the Jade Audio EA3 for the cheapest hybrid using the Knowles RAD-33518.
That holds true if the heart mirror is amped haha. When unamped, SSR is superior in technicalities, so really depends on what source you are intending to bring about.
Whatever the case, heart mirror isn't as shouty in the 3 kHz region as the SSR, so tonally and timbre wise, I also do like the heart mirror better.
Jitu13
In a perfect world, I would have both ssr and heart mirror. Alas, I have to choose one! Getting the er4sr first thing next month, then I will decide between these two.That holds true if the heart mirror is amped haha. When unamped, SSR is superior in technicalities, so really depends on what source you are intending to bring about.
That MT300 is quite temping. I'm waiting to see if there are any further discounts before pulling the trigger.Hello fellow head-fier’s, my review for the MT300 in-ear earphone is finally here!
Enjoy!
-Clear
countryboyhk
- Aug 20, 2010
I admitted MT300's SQ is quite good with beautiful highs, transparent vocals, great soundstage. But, I am also concerned about its QC problem. I've got the 1st batch of MT300 since last June, and the right unit got broken within a month use. The right unit produced 50% less output volume than the normal left unit. The seller sent a replacement right unit after a long request. Unfortunately, the left unit got broken ( the same problem as the right unit ) last month as well. I also found several case reports concerning the 1st batch got broken within my user group. People are saying that electrostatic driver is so fragile to moisture. I don't know, but I have lost all my confidence to this brand.
LaughMoreDaily
Why are you mad the A6 Mini is gone? My left earpiece died within days and now they want me to send a video. I'm too impatient for that.They sold out on Ali on the 11.11. for around 59USD Now they are gone from Ali.
The last time I sent a youtube video to TinHifi and just realized that they can't see it anyway. Waste of time.
By "Tuner", are you referencing an inhouse, TRN employee or Larry Fulton ?The tuner of TRN TA1 had told me it's a warm and bassy sounding signature. I will have it compare to another 1DD 1BA hybrid of 2HT.
Either way, based on Larry Fulton's FR graph, the production unit is neither warm or bassy
L.FultonBy "Tuner", are you referencing an inhouse, TRN employee or Larry Fulton ?
Looks like a IER-Z1R but is tuned nothing like it.By "Tuner", are you referencing an inhouse, TRN employee or Larry Fulton ?
