Uhmmmm. I've been reading the impressions of the Smabat X1 from our mate
@unifutomaki and after that I was a bit worried about the sound and about the result of the switch.
Well, today I got the Smabat X1 and I've only been using it for a couple of hours. First I tried them with the switch in the H (down) position and the sound lacks bass. It's as if the bass driver doesn't work. Then I switched the driver to the upper position and now the bass is quite emphasized. And for me, a bass lover, to say so.... Besides, coming from recently analysing IEMS TFZ it's not easy to scare me.
But really, the X1 (by the way, X1 is perhaps the most recurrent model name in portable audio) has a lot of energy in the mid-bass and a very softened treble start, as if it were an old V-bass IEM, a very classic tuning. There is a tendency to darkness because its high-mids are below the lows, which prevents it from being more detailed and clear.
The mid-bass gets most of the energy, in my opinion too much, which makes the sound more fatiguing. Perhaps it is a matter of turning up the volume to bring the voices, especially the female voices, and the mids closer together, but when the bass comes in, it is too powerful. It is not a muddy sound and there is separation and transparency, but so much presence in the bass, with a sound that is also not very smooth in that low area, but has a certain roughness that detracts from its definition, produces an initial impression that is not very pleasant.
I will need a good brain break-in and also another one for the IEMS, with the intention of softening the bass, extracting more details and getting into its darkness...
In the bassless position, I am not able to hear it. Sorry, I consider myself useless to describe that tuning. Just to say that it's the model with the lowest bass I've been able to listen to and I don't want to try it too much... But I'll give it a try. In this position the bass is unreal, totally incomplete. Voices become shriller and there is a clear sibilance. The sound lacks body and not by removing bass the treble appears or the separation or the details improve. The timbre in this position is wrong, it does not match reality. I'm sure that in the other position it's not the most normal thing in the world either, but many can live with more bass than necessary. In fact, there are IEMS with more bass... and it's just a bit dark, not too dark...
Anyway, I find it difficult to understand that they have configured a switch with such a difference between the two profiles. The sound should not be so polarised, at either end. At 20Hz, the difference is almost 30dB and at 40 almost 25dB. You could live with 10-15dB or reduce the bass curve in the bass position and you'd be close to a Tin HiFi T1 Plus...
Well, here are some graphs...
