1clearhead
- Apr 5, 2013
KZ ZSN and C04 suit your requirement considering you need a mini all-rounder and assuming you're on a budget. Although, it would be helpful if you can specify your budget.
Then ZSN, Vjjb K2 and C10 should serve you good. Can't comment on other choices as I don't own them. C10 ($26) would be my preferred choice in that price bracketThanks. My budget would be similar to most people in this thread I suppose. Around 15$-35$ ? I have my Sennheiser HD599 for more "intense" home use but I recently discovered the world of inexpensive bang for buck chinese audio tech and want to try out some more, especially IEMs. Again thank you.
Just get the T2, if you want neutral and MMCX that's the proven, go-to option.any recommendation for under $50 neutral IEM with mmcx ? so far I just know is the T2
I would suggest the ****. Very neutral and natural sound. Use wide bore tips and lots of power. If you can afford it get a high quality cable as well, it's worth it. At around $25 the **** is amazing value.any recommendation for under $50 neutral IEM with mmcx ? so far I just know is the T2
You prefer the **** to the T2? I see crinacle just got the **** two days ago and didn't like it, and in fact he heard the bass as overwhelming rather than neutral.I would suggest the ****. Very neutral and natural sound. Use wide bore tips and lots of power. If you can afford it get a high quality cable as well, it's worth it. At around $25 the **** is amazing value.
Yes! Glad you like the QCY T1C or QS1 so much. I knew I couldn't be the only one.
this has even better sound than some wired iems on it's price range. really good purchase for me. love it
So I received a little treat today 7 days earlier than scheduled from Amazon US. The Rosewill EX-500, DD+Ceramic D. I've only had around an hour with it but early indications are it has a particularly BIG sound akin to the spaciousness of the **** but with a much meatier sub bass which at first was very distracting but after a while the detail does come thru from a slightly brighter upper mids. It doesn't seem to have the overall resolution of the **** or Artiste DC1 but it can be pretty detailed given the right song/genre. Again, early doors. At the £10 i paid a very good buy.
In other news: just bought the Tennmak Pro (reader suggestion) and TRN H1 to even further expand my abnormal collection.
