plin
- Dec 30, 2010
[size=10.0pt]I forgot to inform another factors which effect a lot to sonic quality. Receptacle at the wall (propery grounding can reduce distortion of the sound), USB cables (connect computer to DACmini or Burson), AC cable (i had already mentioned.) and cable contaction (all type of cables should avoid contact each other at all cost, for example; if wireworld silver starlight 5.2 USB has contaction to AC cable I can hear distortion at treble and irregular rhythm from Burson HA160D, unbelievable but it does occur.). All factors do effect to sonic quality.
The quality of USB cable has effect to Microdetails and tonal balance of the sound.
Wireworld silver starlight 5.2 USB cable delivers more sonic details than Centrance's standard USB cable (that came in the package when purchase DACmini.) But Centrance's standard USB cable delivers smoother treble than Wireworld's USB cable.
I used DACmini with standard USB cable, but I used Burson HA160D with Wireworld silver starlight USB cable. So I can hear more microdetails from Burson HA160D but smoother treble from DACmini.[/size]
[size=10pt]I had tried using Wireworld USB cable with DACmini, the details improof but severely collapse of soundstage so I used DACmini with Centrance's standard USB cable (synergy has a role here).[/size]
[size=10pt]For Burson's standard USB cable (came with Burson HA160D's package) has more bass compare to the other two, soundstage is not as good as Wireworld's USB cable so I use it with Fiio E7+E9 (which help increase bass from HF2 to my satisfied level).
In conclusions both DACmini and Burson HA160D have excellent microdetails, one can produce more microdetails than another if use with better quality and better synergy of USB cable.[/size]
[size=10pt]Regard to music generation.[/size]
[size=10pt]I prefer Burson HA160D and PS500 or LCD2 rev.2 with [/size]Hip Hop, Rock, Metal, Jazz, new age because more bass attack, more treble emphasis, more naunce of each note (guitar, piano, drum, percussion instrument's sound).
I prefer DACmini and RS1i for female singer, wood wind instruments because more fluidity and smoother of the sound.
Very informative, thank you!
